964 Forum 1989-1994
Advice needed using Harbor Freight leak tester
Old 03-06-2016, 10:40 PM
Pak_37
Pak_37's Avatar
Default Advice needed using Harbor Freight leak tester
I am attempting a leak test. Ran engine so it was warm. Set engine to TDC. Attached the Harbor Freight adapter in the spark plug socket to perform test, but it can't be seating well because I show no leakage on gauge but can here slight hissing air leak right at the fitting in the spark plug port. Advice from anyone who has used the HF tester would be appreciated.
Peter
Old 03-07-2016, 07:00 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
JMHO,....
If thats a HF tester, replace it with a Snap-on one as the former ones are just junk.
Old 03-07-2016, 07:20 PM
crg53
crg53's Avatar
HF equipment follows the same recipe as for "LUTEFISK"
Old 03-07-2016, 07:23 PM
Spyerx
Spyerx's Avatar
Received 1,733 Likes on 1,061 Posts
There are some things hf tools are ok for. Measuring devices I'm not sure are at top of list.
Old 03-07-2016, 09:21 PM
Pak_37
Pak_37's Avatar
Thanks for everyone's input. My new mission is to get a better quality tester!
Old 03-07-2016, 09:57 PM
Norse_man
Norse_man's Avatar
throw it my way.
Old 03-07-2016, 10:55 PM
crg53
crg53's Avatar
Lol.
Old 03-08-2016, 01:35 AM
perelet
perelet's Avatar
I used it after putting my engine together on the stand - to make sure rings and valves got seated right before installing engine in to car. Tool served purpose.
Pple love to hate HF , but if you know what you are doing and have reasonable expectation from tool accuracy it should be fine.
heres full thread:
http://forums.pelicanparts.com/porsc...ml#post8657903
That said my tool had no problems with sealing that you are describing, double check your connections and exchange at store if it is deflective.
Oleg.
Sent from my iPad
Quick Reply: Advice needed using Harbor Freight leak tester
