964 Forum 1989-1994
White Wilma - Because White is Right!
Old 04-07-2016, 12:00 PM
Vegas993
Vegas993's Avatar
Default White Wilma - Because White is Right!
3 1/2 years of ownership. Almost two since I embarked on this version. In addition to the aesthetics, she had a compete reseal (100% leak free, lol), and pretty much every oil line, fuel line, seal, ignition components and more were done to the engine. Ruf Cup Pipe and Blower Bypass. Internals are stock and only OEM parts were used. I couldn't have done it without the help of good friends namely Brian from Rotiform and the guys in the shop at my work, Audi Henderson. Happy to answer any questions.
Old 04-07-2016, 01:23 PM
jimonycricket
jimonycricket's Avatar
Beautiful! What is the brake setup on there?
Old 04-07-2016, 01:25 PM
KOTYKB
KOTYKB's Avatar
Your car looks great! Can you give some details on your suspension/brake/wheels?
Old 04-07-2016, 01:33 PM
DTMLGND
DTMLGND's Avatar
Woah! Nice work
Old 04-07-2016, 01:41 PM
Vegas993
Vegas993's Avatar
Thank you. Brakes are the Brembo GT kit, 355mm front and 328mm rear, 4 Piston. Super easy install, basically an even swap with the OEM setup and replace the OEM lines from the chassis with Goodridge SS.
Suspension is H&R DEEP Coilovers from AH Exclusive in Germany, distributed by Rotiform here in the US. They are shortened with a very stiff linear spring. I don't recall the spring rates but they allow you to ride low with very little travel. Full droop is like stock ride height, lol.
Wheels are custom made by Rotiform, 3 piece, satin ceramic black with polished paddles and gloss ceramic clear, 18 x 8.5 et39 w/ 1" lip and 10 et35 w/ 3" lip, tires are Conti DW 215/40 and 245/35. Camber is -2.0º in the front and -3.0º in the rear.
Old 04-07-2016, 01:51 PM
Vegas993
Vegas993's Avatar
Wait a minute, the haters are quite? That's pretty funny! You guys feeling alright? Hahaha!!!
Jjm4life
Jjm4life's Avatar
Sex.
That is all.
Old 04-07-2016, 01:54 PM
Vegas993
Vegas993's Avatar
Lol, thanks man.
Old 04-07-2016, 02:08 PM
sander97C2
sander97C2's Avatar
Dude, it looks very very badass. Love what you've done with the seats, the colors inside and out, Roti's nicely fitted it all works together perfectly. Well done. Lot of work put into the car for sure. Respect!
Old 04-07-2016, 02:13 PM
Vegas993
Vegas993's Avatar
Thank you, I appreciate that. It sure seemed like a lot of work on my end, lol. I guess it's good that it shows!
Old 04-07-2016, 02:22 PM
creaturecat
creaturecat's Avatar
i would paint the headlight rings to match the car.
there you go.
Old 04-07-2016, 02:26 PM
Vegas993
Vegas993's Avatar
Hahaha, nice. I may get a set covers painted to switch it up now and then.
Old 04-07-2016, 02:31 PM
Spyerx
Spyerx's Avatar
Received 1,733 Likes on 1,061 Posts
some up close shots of the fitment on the front/rear fender to tire/wheel and inner would be interesting. Those are super aggressive offsets and guessing the high camber plus narrow (for the wheel) tire sizes are why they fit.
i'm at ET51 rear on a 10" with a 275 and it looks just as close as yours, can't get a finger in there!
Front i'm ET 47 on a 8.5" with a 235 and it's SUPER tight.
I like the fat, meaty look on the tires vs. stretched (my opinion/style).
Old 04-07-2016, 02:33 PM
Vegas993
Vegas993's Avatar
That would be correct. I'll be at Luft and you can see it in person!
Old 04-07-2016, 02:39 PM
Vegas993
Vegas993's Avatar
I have more room that it looks like in the pics, especially the rear. I was even thinking of backing off some of the camber as I was running 255's on my last wheels. I'll probably leave it as is though as the wheel lip is pretty much flush with the fender and I like the way it looks.
Quick Reply: White Wilma - Because White is Right!
