C2 cranking but not starting
So I'm stranded waiting on a tow truck. Car it cranking but not turning over. It was driving so well for the past few days.
Last year I replaced the spark plugs, wires, caps, rotors, coils, dme, fuel filter, idle valve controller. It's been running great but now this
Any ideas guys? Could the dme have failed in a couple months? Should I have replaced the fuel pump?
Check the idle microswitch to make sure there is contact when throttle not depressed.
Sometimes the throttle cable can get sticky within the tube under the car.
Got to be simple problem.
Listen for fuel pump
Replace DME with spare if you have
Check idle microswitch.
Try to start the car on one set of plugs by pulling harness off secondary coil controller
(in case of broken distributer belt, or loose plug wire ect)
good luck
FS
good luck
FS
Thanks guys i'll give those a try and see what happens tomorrow =( so sad first day of good weather and she's acting up. I dont think i hear the fuel pump when the key does in and turns on. So maybe its not pressurizing.
Thanks News boys Im going to try you suggestion today =( Havn't had to get a car towed in over 10 years. Bringing me back to my Toyota MR2 days =/
I hope it's a simple fix for you!
So far it's been a wild goose chase from one suspect to another. But I think I'm getting closer.
Few things for you to check:
As others have said, see if you can try another DME Relay. You can jumper it.
Getting to the fuel pump to check it is slight pain. Jack up the car, remove the cover/plate... To check for voltage there, you might have to pull the fuel pump down to access the electric connections
If that checks out, you should check if you've got spark. This is where I am failing. I have no spark.
Traced it to a possible problem with my voltage regulator. I am getting less than 12v at either of my ignition coils when measured at the +/- terminals on top of them. Check this on yours to make sure you've got voltage.
Then pull a spark plug wire out and with a spare spark plug, check for spark....
If you don't have spark, and you likely don't, then it could other things...as it turns out, a lot of other things.
If you have fuel AND spark, then I don't know what you're dealing with. Should fire right up!
OK so once I got the car home it started up fine and I drove it around the block and seemed fine. Couple days later I drove it to work and at the end of the day it would turn over for a few seconds then die. Towed again.
I have now replaced the fuel pump , DME again and also replaced the Flywheel speed sensor. The Flywheel speed sensor definitely made a difference to how smoothly the car revs up now but the idle is still a bit rough. Also the old fuel pump looked pretty mint and it looked like someone was in there recently. Im scared to take her out too far from home. ugh. Anything else you guys can think of.
Replaced so far:
spark plugs
spark plugs wires
Distributor caps
rotors
coils
dme relay
fuel filter
Head Temperature sensor
Fuel Pump
Flywheel Speed senor
New Battery
Microswitch is working correct and AFM is good as well
Replaced so far:
spark plugs
spark plugs wires
Distributor caps
rotors
coils
dme relay
fuel filter
Fuel Pump
New Battery
It starts and idles for like a few seconds but then dies. I can keep it going by revving it but as soon as foot comes off it dies.
Pull easy to reach spark plug boot off plug, get another spare spark plug, insert into boot and ground the side of the plug to generally anywhere on engine, crank car to look for spark. Obviously this takes two people.
I had a no start issue, ended up being a bad coil, and weak spark plug wires. I reversed the wires coming from the coils to the distributors, and it fired right up. Ended up replacing both coils and spark plug wires.
