Let's talk track pads
#31
Front 4 piston (36 and 40mm): 3.14 * 18^2 + 3.14 * 20^2 = 2273 mm^2 of area
Rear 2 piston (44mm): 3.14 * 22^2 = 1520 mm^2 of area
Rear 4 piston (28 and 30mm): 3.14 * 14^2 + 3.14 * 15^2 = 1322 mm^2 of area
You can divide the front area by the rear to get the respective 1.496 and 1.720 ratios. So the more hydraulic force you can apply over a larger area the more brake torque you can generate. Therefore since the 2 piston has a larger area it can generate more brake torque, but it will overheat quicker and not last as long as the larger pads found in the 4 piston caliper - hence why it's not really "better" even though it's hydraulically superior.
The proportioning valve reduces the pressure and therefore braking torque of the rear calipers once the driver has applied over the "knee" pressure of either 45 or 55 bar. This causes the brake bias to significantly shift to the front calipers causing them to be overworked and the rears to be underutilized.
Make sense?
#32
#34
here are few of the newer racecar set ups w/ dual masters for further comparison
#35
I've used RS29 for many years and like them a lot. But since two years ago I switched to Hawk DTC60. Very similiar to RS29, easy to modulate and long lasting. The big flip side is the price level. Much cheaper than pagid.
#36
As for the RS29 Yellow squealing? I'd refer to it more as 'howling'. It's truly amazing how loud they can be.
#37
I'm currently using RS29 Pagid Yellow in front, and Pagid Black in rear. I have no complaints for 'endurance' (DE) work, as they last well; however, I'm considering other options to give better bite and feel. Maybe PFC?
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
