964 Forum 1989-1994
Check engine light - O2 sensor
Old 06-11-2016, 09:04 AM
banzaisan
banzaisan's Avatar
Default Check engine light - O2 sensor
Hello,
I recently rebuilt my engine and purchased a new exhaust system. Since I run a mixture of 110/93 octane gas I didn't reinstall my O2 sensor. Now my check engine light turns on once the car is warmed up. When my shop checked the DME, it shows the O2 sensor at fault.
Has anyone figured out a way to bypass this code without reinstalling the sensor?
Thanks in advance.
--Dave
Old 06-11-2016, 09:18 AM
Spyerx
Spyerx's Avatar
Received 1,746 Likes on 1,068 Posts
Why aren't you running the sensor?
The car uses this for engine control
Old 06-11-2016, 09:56 AM
banzaisan
banzaisan's Avatar
My car use to be a full time race car which I converted back to street. I still like to run mixture of 110/93 octane fuel. If I reinstall the O2 sensor, I think it will produce an error code as well.
Old 06-11-2016, 12:22 PM
Jjm4life
Jjm4life's Avatar
How precise is this fuel mix? Other than additional detonation protection at the track I can't imagine mixing the higher octane actually does anything. Why not just run pump gas, install the sensor and have your engine management system perform correctly? I'd imagine it would actually run better
Old 06-11-2016, 01:15 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
You can Jumper the ECU.
Quick Reply: Check engine light - O2 sensor
