964 Forum 1989-1994
Crazy or there's a mint green coupe in there
Old 08-09-2016, 05:38 PM
JohnK964
JohnK964's Avatar
Default Crazy or there's a mint green coupe in there
You might guess crazy but that's ok. I want her back to mint green and decided I wanted to see as much of her in original paint so wet sand away the blue makes a good guide coat
Old 08-09-2016, 05:40 PM
Goughary
Goughary's Avatar
Keep going!!!!!
Old 08-09-2016, 05:41 PM
onceover
onceover's Avatar
Amazing that someone would paint over such a unique color
Nylasurf
Nylasurf's Avatar
Bring back the minty goodness - looks like a winning scratch off lottery ticket
Old 08-09-2016, 06:05 PM
JohnK964
JohnK964's Avatar
Default believe it or not
Who ever did this to her didn't even use primer
Old 08-09-2016, 07:02 PM
tjb616
tjb616's Avatar
And if they didn't use primer, maybe the didn't prep the original paint by sanding... You might be able to sand down to the original clear coat. Wax, polish, original paint!
Old 08-09-2016, 08:14 PM
Streetdaddy
Streetdaddy's Avatar
Probably couldn't give away a mint green 964 10 years ago!
Old 08-09-2016, 08:21 PM
02m2
02m2's Avatar
Looking forward to seeing this come back together in all its minty goodness .
Old 08-09-2016, 09:24 PM
JohnK964
JohnK964's Avatar
No such luck also the windows were taken out when painted blue I think in 1998 so for now I sand it drive it mostly drive and will take apart in the winter
Old 08-10-2016, 12:29 AM
hockenheimr
hockenheimr's Avatar
Keep on going! 964 windows for the most part just pop out...literally. The only one you might have to cut the seal on is the rear. The door windows don't have to be removed as the frame between the window and paint also just pops out and is held in by metal clips.
Good luck!
Old 08-10-2016, 09:26 AM
JohnK964
JohnK964's Avatar
Next stop sunroof panel then down the a pillars😃
Old 08-10-2016, 09:57 AM
tfitch03
tfitch03's Avatar
how are you removing the top layer of paint?
Old 08-10-2016, 10:25 AM
Norse_man
Norse_man's Avatar
"Wet sand away"
Old 08-10-2016, 10:50 AM
hockenheimr
Originally Posted by JohnK964
Next stop sunroof panel then down the a pillars��
Gutsiest move I ever saw, John!
Old 08-10-2016, 11:27 AM
JohnK964
JohnK964's Avatar
Default my wife votes crazy
Thank You! I know I will have to shoot new mint over the old but doing it this way entertains me Thanks to all
Quick Reply: Crazy or there's a mint green coupe in there
