964 Forum 1989-1994
Understanding Oil Tank, oil lines and Breather
Old 04-24-2024, 09:42 PM
  #91
Gus
Gus's Avatar
What is the thickness of the aluminum sheeting that you used. Very good job, looks really trick-
Old 04-24-2024, 09:54 PM
  #92
RevivalRoadFab
5th Gear
RevivalRoadFab's Avatar
I believe 16ga. Would probably do it out of 14 ga. next time thought it is pretty firm for how large it is.
Old 04-25-2024, 01:08 AM
  #93
spartansix
spartansix's Avatar
How many hours went into that beauty?
Old 04-25-2024, 10:02 PM
  #94
RevivalRoadFab
5th Gear
Probably a weeks worth of time at least. Lots of back and forth forming it, adding features, designing, drawing in cad, plasma cutting materials, and fabricating the subframe that holds the undertray, then splitting the tray into two so that the transmission section stays stationary since its mounted to the tub. 2nd time around is always faster...
Quick Reply: Understanding Oil Tank, oil lines and Breather
