964 Forum 1989-1994
964/Cost of New Engine?
Old 10-29-2016, 11:10 AM
bauerjab
bauerjab's Avatar
Default 964/Cost of New Engine?
I am looking at a 964 that has a blown engine, allegedly has cracked cylinder head and broken connecting rods. Assume the wiring is fine. How much is a new engine? Anyone know. Thanks!
Old 10-29-2016, 11:13 AM
Andy Roe
Andy Roe's Avatar
It depends on what needs to be re-built. My guess anywhere from $10-15K upwards, but some more local people will probably be able to help!
Old 10-29-2016, 12:00 PM
964Andrew
964Andrew's Avatar
I don't think there are any "new" 3.6l 964 engines around anymore. I've seen some used in decent condition between 10K - 25K over the years. If you want something more than stock power output then you are looking easily 30K+ for custom build engine.
Thanks!
Andrew
Old 10-29-2016, 12:50 PM
Jjm4life
Jjm4life's Avatar
By the time my engine was back in it was 30k+. Needed new heads cams oil pump.. honesty not much is original at all. Gives you an idea of the cost.
Old 10-29-2016, 04:42 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Without seeing it for myself, all I can offer is an educated guess based on some experience at this.
I would budget $20-25K for a complete, proper rebuild.
Old 10-29-2016, 10:21 PM
JJJMCD
JJJMCD's Avatar
Have prices for used 964 engines really gone up that much? The last time I checked (probably 6-7 years ago), they could be had for $7-10k. I would check with LA Porsche Dismantlers, Autobahn Dismantlers, Oklahoma Foreign and DC Auto.
Here is a complete 993 engine for $14k:
http://m.ebay.com/itm/Porsche-911-993-Non-Vario-Ram-Complete-Engine-Conversion-SC-914-3-6-Liter-Motor-/162164314504?fits=Make%3APorsche%7CModel%3A911&hash=item25c1bf1188%3Ag%3 ADmwAAOSw65FXqm2z&_trkparms=pageci%253A9ff8755d-9e3e-11e6-9bc5-74dbd1806941%257Cparentrq%253A1329b00c1580a786c35ad3f6fffd5999%257Ciid%2 53A9
Old 10-30-2016, 06:30 AM
newsboy
newsboy's Avatar
Vertex sells 3.6 for 12K, rebuilt with 1 year warranty, with your old block.
Old 10-30-2016, 09:23 AM
u7t2p7
u7t2p7's Avatar
I wouldn't recommend buying an engine from Vertex!
Old 10-30-2016, 10:25 AM
onevoice
onevoice's Avatar
For negotiating purposes, go with Steve's numbers. They should cover everything.
It could be a lot less, you won't know until it is opened up. A broken rod could ruin a lot of very expensive parts. I broke a rod in a race engine once (non Porsche) and all that was usable afterwards was the intake and carb.
The price for complete used 3.6 engines has risen to the $12-16k range, and you are rolling the dice with one.
Old 10-30-2016, 11:24 AM
tsp533
tsp533's Avatar
The complete rebuild of my 1990's 3.6L completed in May 2016 ran just short of $24,000.
Quick Reply: 964/Cost of New Engine?
