964 Forum 1989-1994
Door Pocket Repair
Old 11-20-2016, 05:14 PM
Pak_37
Pak_37's Avatar
Default Door Pocket Repair
The plastic in the door pocket is cracked and I've made a plate to reinforce - I used a 3d printer to print the "plate" and epoxied it in place. Here are some photos and a link through One Drive to the .stl files used to 3d print so anyone who has access and wants to duplicate help yourself.
There are 2 files - one for the passenger side and one for the driver side - you cannot just print 2 of one and flip it over.
https://1drv.ms/f/s!AiRLN5qAXcmfgRr0XnXzrvpj_VB-
nbegood (12-29-2022)
Old 11-20-2016, 08:14 PM
-Danno-
-Danno-'s Avatar
Thanks!
Old 11-20-2016, 08:23 PM
dlpalumbo
dlpalumbo's Avatar
Looks good. Now to find a printer!
Thanks.
Old 11-21-2016, 11:29 AM
Streetdaddy
Streetdaddy's Avatar
Does kinkos have 3d printers?
Old 11-21-2016, 02:25 PM
ramans
ramans's Avatar
awesome thank you!
Old 11-21-2016, 02:42 PM
Deserion
Deserion's Avatar
If anyone makes a second set, I'd be interested in buying.
Old 11-21-2016, 10:18 PM
JohnK964
JohnK964's Avatar
Me too 👍
Old 11-22-2016, 02:36 AM
gw911nine97
gw911nine97's Avatar
hey guys, check out 993 forum on this fix as there was someone who makes & sells them.
Old 12-03-2016, 08:42 PM
BesideTheBox
BesideTheBox's Avatar
Hi Pak_37,
Very generous of you to contribute your STL file to the Rennlist community.
You definitely have a non-HiFi door pocket, but the profile of your cracked bracket looks like the profile of the 993 HiFi door pocket bracket.
There is a company called Leather Restorations that sells a bracket to replace a cracked non-HiFi door pocket bracket. Its profile looks similar to yours.
Is it possible that your door pocket bracket was previously replaced?
I could be wrong about this, but I thought that all 964 models had non-HiFi door pockets with the bracket profile shown below.
BTB
Aerial view of standard door pocket bracket (ABS sheet reinforcement matched up on left side)
Aerial view of standard door pocket with the Leather Restorations replacement bracket installed.
Old 12-05-2016, 03:48 PM
HiWind
HiWind's Avatar
nicely done!
Old 01-08-2017, 04:50 PM
07CarreraS
07CarreraS's Avatar
Has anyone been having the issue where the door pocket bows outward?
When I close the lid on the door pocket, the lid sinks inside instead of closing flush on top. Hope that makes sense
Old 01-09-2017, 10:25 AM
BesideTheBox
I've seen pictures of door pockets that are truly bowed/curved, but I've also seen pockets that were just aligned poorly.
If the alignment is off along the entire length of the pocket/lid, then you can adjust this alignment by drilling a new hole for the screw that goes through the plastic of the door pocket (the part that typically cracks) into the door handle.
I hope that makes sense.
Old 01-09-2017, 11:48 PM
dlpalumbo
dlpalumbo's Avatar
Finally found a printer, but when I looked at the STL files they were scaled differently. One was very much bigger than the other. Can anyone give me the correct dimensions for these pieces?
Thanks,
Dan
Old 01-09-2017, 11:57 PM
Pak_37
Pak_37's Avatar
Thanks,
Dan
Hi Dan
Sorry the files arent correct. We are travelling and will not be able to look at them until the beginning of February. I will correct and re-post then.
Old 01-11-2017, 08:16 PM
dlpalumbo
dlpalumbo's Avatar
Thanks Peter.
Quick Reply: Door Pocket Repair
