Spring plates bushes replacement options
Hi guys,
My rear spring plates bushes needs replacement,
As suggested by a few people here Elephant Racing in US is providing a kit at 560 $, cheaper than buy new ones but still .....
Any ideas
By the way for those who are looking for trailing arm bushes Powerflex now makes the kit for 160 $ each side, I though it's very reasonable.
Any ideas
go with the ERP parts spingplates that replaces the whole assembly , tarett engineering also sells a set.. 750 retail but worth it IMO, it makes toe and camber adjustment so much easier
Just a point of clarification regarding Powerflex "now makes a kit" for the rear trailing arms.
Powerflex has made this kit for a long time and was actually the first to offer a bushing replacement that allowed servicing of the rear trailing arm (rather than replace the whole unit). There's an old thread on here from 9M (Ninemeister) about how 9M worked with Powerflex to develop a solution for the worn trailing arm bushes.
Ugh. I bought that Powerflex bushing kit for the rear trailing arm and proceeded to hammer out the ring inside the bushing seat on the arm. That is required for the Elephant kit, but you have to leave it in for the Powerflex bushing. Returned the PF, ordered Elephant. I'm happy I have real rubber instead of urethane, but spending $750 on two bushings is really tough to swallow.
I also used Elephants spring plate bushing replacement kit, but I'm now wishing I had ordered the ERP full replacement ones.
Oh well. At least everything is fresh and ready to go. Best of luck with whatever you decide, but you cant go wrong with Elephant products or ERP. Quality parts and excellent customer service from Elephant (no experience with ERP.)
Hi guys ,
thanks for all your comments , It seam that it makes sens to invest the all spring plates from ERP ,
had the outer steering arms from them and the quality is very good ,
cheers
Konstantin
cheers
Konstantin
i have just fitted 935 style springplates and FVD monoball bushings in the trailing arm (and monoball bushings in the front wishbones and monoball topmounts :-)) and this was/is great.
They have a discount at the moment for the bushings: https://www.fvd.net/de-de/FVD3315001...qualitaet.html
https://www.fvd.net/de-de/FVD3315002...qualitaet.html
Spring Plate Bushing SEALS
I just pulled my rear spring plates from the car because I noticed grease leaking from the bushing area and suspected they were spent. Upon inspection the joints/bushes/monoballs are fine. I do need the seals for both sides. Has anyone ever sourced these?
Those seals don’t exist. I thought about havjng them made once and did a couple trials. But wasn’t successful. After a bit I gave up and bought the elephant replacement bushings. From what I found , they were the best and least expensive option in going with an effectively oem replacement (performance wise)...
If I do it again, I’m going with the tarret plates. They won’t last as long but better performance.
For street, best bang for the buck are the elephant bushings. But if you find seals, let us know. I have some plates i would restore. Those oem monoball rarely fail. Most replace them due to bad seals - prematurely.
my race time is with classic motorcycles,
i have the elephant racing spring plate bushing replacement and could not complain. it works VERY well. i also changed all the front and rear bushing with the FVD monoballs (looks very similar to the Elephant products though -might have come from them anyway) and the handling of the car is transformed. i have the bilstein pss10 suspension and some sway bars and strut bar. but all those mods just made the car handle and feel like a modern car with a lot of feedback.
