322mm Brake Discs
#31
I am not familiar with the Endless pads.
Have you tried Ferodo DS-11's I have many friends with great results. They claim they have the braking force of the pagid blacks and longevity of pagid yellows and easy on rotors.
#33
Hi Roland
Due to my setup I used to run 964 Turbo II discs, but being drilled discs and using RS29 pads I too had numerous cracking issues after 203 trackdays...replacing discs well before they were worn ££££££££££££££££.
I now use a custom made set of 2-piece slotted front discs from MTEC (https://www.mtecbrakes.com/) (https://www.mtecbrakes.com/2-piece-brake-discs.html), no affiliation.
Can't fault them, cheaper than other options and lighter than the 965 sebro I used to use! (tip: I sent them one of my discs as well as sending back their template), give them a call for a quote!
Was put onto them by a BMW driving track mate.
Some pics of my fitment here....
https://t.co/Ah951M7pSD
#34
Hi Roland
Will use them for 3.6T disc slotted.
#35
Anything here that would work?
https://www.racingbrake.com/category-s/7461.htm
Seem to get good life out of them:
https://rennlist.com/forums/928-foru...ne-season.html
#36
Hi Roland
