NO INSTRUMENT LIGHTS AND TAIL LIGHTS!!!
Does anyone know what fuse,fuses or relay work the tail lights and the instrument lights? I have a 1991 c2 Turbo and just last week having not driven it in over a month discovered both problems have occured at once. I checked the fuse box in the front trunk and can't find a common fuse or even the tail lights even listed! Any ideas would be great. THANKS IN ADVANCE!!
I may be mistaken and don't have access to the manuals now, but I don't believe the tail lights and instrument lights are on the same fuse. It sounds like your problem may be in the switch itself or associated wiring off of the switch. I am assuming your headlights and front marker lights are working?
Headlights, front and rear turn signals and brake lights when activated all work. Also all instrument gauges work. And yes I have turned the dimmer switch for the instruments clockwise to brighten lights to no avail.
