classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
User
Hi all
I have a 1993 964 3.6 turbo which is due a full service. I live in Spain and am a long way from a Porsche dealer. My local garage has a good reputation and services a range of sports cars as well a top saloons, but obviously doesn't do Porches everyday! I would be quite happy to have it serviced there but wondered if someone could give me an idea of what the main service items/procedures would be - e.g. oil filter, fuel filter etc. I/the garage can pre-order these parts to save me having the car off the road for days/weeks. I know they may find other issues, but at least if I have the basic stuff ready, it would help. Also, anything I should watch out for when "briefing" the garage. I have tried googling but all get is offers to service it for me! Thanks for any help you can give RJ |
#2 |
User
Hi RJ,
you should have a service manual in your car, look through it, it should provide you the necessary details. I can only provide you the info in German. Cheers, hvh PS: Source http://www.pocg.de/technik/allgemein...ktionsplan.htm Wartung bei 3.000 bis 4.000 km 1. Diagnosesystem: Fehlerspeicher auslesen 2. Bereifung: Zustand und Reifendruck prüfen 3. Sichtprüfung auf Dichtheit: Öle, Flüssigkeiten 4. Scheibenwaschanlage: Flüssigkeitsstand prüfen, in den Wintermonaten Frostschutz beachten 5. Beleuchtungsanlage: auf Funktion prüfen 6. Abgasanlage: Sichtprüfung auf Dichtheit und Beschädigung Probefahrt: Fuss- und Handbremse, Kupplung, Tempomat, Lenkung, Heizung, Klimaanlage und Instrumente auf Funktion prüfen * Danach erneut Sichtprüfung auf Dichtheit: Öle und Flüssigkeiten Wartung alle 20.000 km Prüfen und bei Bedarf ersetzen: 1. Diagnosesystem: Fehlerspeicher auslesen 2. Motoröl und Ölfilter wechseln 3. Ventilspiel prüfen und ggf. neu einstellen 4. Keil- bzw. Polyrib-Riemen: Zustand und Spannung prüfen 5. Zahnriemen für Servolenkung : Zustand prüfen 6. Zündkerzen ersetzen (nur bei Fahrzeugen ohne Katalysator) 7. Ladedruck - Sicherheitsschalter prüfen 8. Sichtprüfung auf Dichtheit: Öle, Flüssigkeiten 9. Luftfilter: Filtereinsatz ersetzen 10. Kurbelgehäuseentlüftung: Schlauchanschlüsse auf Festsitz prüfen 11. Kraftstoffanlage: Sichtprüfung auf Beschädigung, Verlegung und Festsitz der Leitungsverbindungen 12. Ansaugluftführung: Schläuche, Leitungen und Anschlüsse auf Festsitz prüfen 13. Handbremse: Leerweg des Handbremshebels prüfen 14. Bremsanlage: Sichtprüfung der Bremsbeläge und Bremsscheiben auf Verschleiß 15. Bremsschläuche und Leitungen: Sichtprüfung auf Beschädigung, Verlegung und Korrosion, Bremsflüssigkeitsstand prüfen. 16. Kupplung: Spiel bzw. Pedalendstellung prüfen 17. Drosselklappenbetätigung: Auf Leichtgängigkeit und Vollgasstellung prüfen 18. Resonanzklappe auf Funktion prüfen 19. Lenkgetriebe: Sichtprüfung der Faltenbälge auf Beschädigungen 20. Spurstangengelenke: Spiel und Staubkappen prüfen 21. Servolenkung: Flüssigkeitsstand prüfen 22. Achsgelenke: Sichtprüfung der Staubkappen auf Beschädigungen, Schraubverbindungen der Fahrwerkseinstellung vorn und hinten auf Festsitz prüfen 23. Getriebe / Achsantriebe: Olstände prüfen 24. Automatikgetriebe: ATF-Stand prüfen 25. Gelenkwellen: Sichtprüfung der Manschetten auf Dichtheit und Beschädigung 26. Abgasanlage: Sichtprüfung auf Dichtheit und Beschädigung, Aufhängung prüfen 27. Bereifung: Zustand und Reifendruck prüfen 28. Türscharniere: Ölen 29. Tür, Deckelschlösser und Sicherheitshaken des vorderen Deckels auf festen Sitz und Funktion prüfen 30. Sicherheitsgurte: Funktion und Zustand prüfen 31. Dichtungen für Türen, Deckel und Dach: Gummiabrieb entfernen, Dichtungen mit geeignetem Mittel pflegen 32. Fahrzeug-Beleuchtung auf Funktion prüfen 33. Alle Scheinwerfer: Einstellung prüfen 34. Signalhorn: Funktion prüfen 35. Scheibenwaschanlage, Scheinwerferreinigungsanlage: Flüssigkeitsstand und Düseneinstellungen prüfen, in den Wintermonaten Frostschutz beachten 36. Alle übrigen elektrischen Einrichtungen sowie Kontroll- und Warnleuchten: Funktion prüfen 37. Zündkreis 1 und 2: Funktion prüfen Probefahrt: Fuss- und Handbremse, Kupplung, Tempomat, Lenkung, Heizung, Klimaanlage und Instrumente auf Funktion prüfen * Danach erneut Sichtprüfung auf Dichtheit: Öle und Flüssigkeiten Wartung zusätzlich alle 40.000 km 1. Kraftstoffilter ersetzen 2. Lüftfilter: Filtereinsatz ersetzen 3. Zündkerzen ersetzen (nur bei Fahrzeugen mit Katalysator) 4. Automatikgetriebe: ATF und ATF-Filter wechseln Wartung zusätzlich alle 80.000 km 1. Schaltgetriebe / Achsantrieb: Öl wechseln 2. Automatikgetriebe: Öl im Achsantrieb wechseln Wartung alle 3 Jahre 1. Bremssflüssigkeit wechseln von Porsche empfohlene Jahreswartung 1. Diagnosesystem: Fehlerspeicher auslesen 2. Sichtprüfung auf Dichheit: Öle, Flüssigkeiten 3. Handbremse: Leerweg des Handbremshebels prüfen 4. Bremsanlage: Sichtprüfung der Bremsbeläge und Bremsscheiben auf Verschleiß 5. Bremsflüssigkeitsstand prüfen 6. Lenkgetriebe: Sichtprüfung der Faltenbälge auf Beschädigung 7. Spurstangengelenke: Spiel und Staubkappen prüfen 8. Achsgelenke: Sichtprüfung der Staubkappen auf Beschädigung 9. Gelenkwellen: Sichtprüfung der Manschetten auf Dichtheit und Beschädigung 10. Abgasanlage: Sichtprüfung auf Dichtheit und Beschädigung, Aufhängung prüfen 11. Bereifung: Zustand und Reifendruck prüfen 12. Dichtungen für Türen, Deckel und Dach : Gummiabrieb entfernen, Dichtungen mit geeignetem Mittel pflegen 13. Beleuchtungsanlage auf Funktion prüfen 14. Scheibenwaschanlage, Scheinwerferreinigungsanlage: Flüssigkeitsstand und Düseneinstellung prüfen; in den Wintermonaten Frostschutz beachten. 15. Batterie: Säurestand und Säuredichte prüfen 16. Alle übrigen elektrischen Einrichtungen sowie Kontroll- und Warnleuchten: Funktion prüfen 17. Zustandsbericht für Langzeitgarantie erstellen (erstmals nach Ablauf von 2 Jahren) Probefahrt: Fuß- und Handbremse, Kupplung, Tempomat, Lenkung, Heizung, Klimaanlage und Instrumente: Funktion prüfen * Danach erneut Sichtprüfung auf Dichtheit: Öle und Flüssigkeiten Last edited by hvh; 05-17-2009 at 05:52 PM. Reason: Adding source |
#3 |
User
Thanks for replying. I was beginning to think that no one would answer! Anyway - unfortunately, I do not have the service manual or books. The car came without them. I do have a few bills and am looking through them to see what is there.
Unfortunately I do not speak one word of German. Hope your reply helps someone but it won't help me!! Cheers RJ |
#4 |
User
Well - spoke too soon! I cut and pasted your advice into an internet translator and wonders of wonders - most of it came through OK. So it is a good start.
Thanks again for helping. RJ |
#5 |
User
No service manual? Hm. Brave! Hopefully many bills to document service. Watch for the absolutely necessary valve adjustments! If not - have it done! Oil change? If not - have it done! The engine is the heart and the most costly part.
Cheers, hvh |
#6 |
User
Thanks for the advice. BTW - no service manual because it "disappeared" when in for a service at a Porsche dealer a year or two ago. Read into that what you will
![]() RJ |
#7 |
Rennlist Member Join Date: Jun 2001
Where in Spain? Porsche has service centres in just about every province. I hope you get it resolved.
RLM 001222-2342 '83 944 gemini gray metallic '90 944S2 cabrio linen metallic '91 951 cabrio #209 of 528, black |
#8 |
User
[quote=Luis de Prat;6594305]Where in Spain? Porsche has service centres in just about every province. [quote]
You are right - there are service centres OK! My nearest (still a fair way away) is Marbella Porsche. If you know Marbella - it is the richest area in South Spain. Charges are around 70 Euros (and pounds now) per hour. They manage to find enough "wrong" to push the price up to 2-3000 for every service or repair. Then, because you are such an important customer, they park your 964 turbo well round the back out of sight, because it gives the owners of the latest Porsches a bad feeling to see this old cr*p parked in the service bay next to theirs. Sorry - went twice, never again. RJ |
#9 |
User
Hi RJ,
i service the car (3.6) myself and i think as long as we we talk about ordinary maintance your local shop should be able to do it well. specific porsche turbo knowledge is requested if it comes to fix any troubles. regarding the costs you should have in mind that access to the engine is time-consuming. to check the valve clearance for instance you have to remove wastegate, intercooler and some parts of the SAI. if you´re interested PM me your e-mail address, i´ll send you the maintanance chapter out of the workshop manual (english). fritz |
#10 | |
User
Quote:
Richard |
| Tags |
| ersetzen, zundkerzen |
| Thread Tools | |
