964 Turbo Forum 1989-1994
My K27 HFS results
Old 04-06-2010, 06:02 PM
watsonj0
watsonj0's Avatar
Default My K27 HFS results
I know we all like dynoplots to critique
I had my car finally get to the Dyno today @ Auto Edge.
Bob has a really neat programable system for the CIS that works great AFR's are no problem
Here is the sheet.
Old 04-06-2010, 07:42 PM
Metal Guru
Metal Guru's Avatar
Tell us about the mods made to give you 11.5/1 AFR at max rpm. Usually CIS doesn't fuel the higher engine speeds well, even when using the stock K27.
Old 04-06-2010, 08:22 PM
watsonj0
watsonj0's Avatar
It uses a unit developed by auto edge and a fuel injection engineer, I am not sure of all the ins and outs but it is a laptop programable unit with a proper fuel map that controls the pressure across the CIS I do know that supporting 600HP with this setup and CIS should be possible as we were able to get A/F into the 9's with only 75% duty all the way to redline.
Give Bob a call.
Jon
Old 04-06-2010, 08:28 PM
Metal Guru
Metal Guru's Avatar
Jon, great info. Will do.
The power figures: flywheel hp or rear wheel hp? Also, what boost were you running?
Thanks.
watsonj0
watsonj0's Avatar
Wheel HP .9 bar
Here is a link to some build details:
http://www.auto-edge.com/pages/Proje...el=965%20Turbo
Old 04-09-2010, 08:03 PM
maverick
maverick's Avatar
How cool...your HP curve is the outline of the Panamera
Old 04-11-2010, 11:19 AM
Metal Guru
Metal Guru's Avatar
Jon, wow, you've done a lot of stuff there!
Is the Whipflash system proprietary? Google didn't find any hits.
Besides the HFS, l/w flywheel and headers, were any other mods done to the powertrain?
Lastly, please compare the l/w flywheel to the dual mass one for starting and acceleration.
Thanks.
Old 04-11-2010, 11:24 PM
watsonj0
watsonj0's Avatar
the whipflash is built by the shop so there wont be much info out there.
I re-geared the tranny with a close ratio 2-5 set so it will stay on boost/cam during the shifts
Old 04-12-2010, 09:25 PM
Metal Guru
Metal Guru's Avatar
Nice.
How do you like the l/w flywheel? Please compare it to the stock dual mass flywheel.
Old 04-12-2010, 10:00 PM
maverick
maverick's Avatar
I have had the L/W flywheel and clutch for about 5 years...it's a lighter feel but no noise issues that are often reported and the engine spools so much quicker and is more responsive to throttle input.
Old 04-13-2010, 07:24 PM
Metal Guru
Metal Guru's Avatar
Andrew, thanks.
Old 04-13-2010, 08:43 PM
Steven C.
Steven C.'s Avatar
Be careful Paul, you are conversing with a guy who drives our track backwards
Old 04-15-2010, 09:34 PM
maverick
maverick's Avatar
No wonder no one passed me
Old 04-18-2010, 09:00 AM
Metal Guru
Metal Guru's Avatar
Jon, what was the cost of the CIS management?
Old 04-18-2010, 09:54 AM
watsonj0
watsonj0's Avatar
I dont have the bill at home, but I remember it was $1000,00 for the unit installed, tuned including dyno time. I will check Monday.
the flywheel makes a Positive difference, revs quicker I have no idle issues ext .
Quick Reply: My K27 HFS results
