k29 turbo users pls chime in
I have a powerhaus k29 in my 3.3 and wondering if I should go down to a k27 7200 for more usable power and longevity of the motor. Anyone have negative experiences w the k29? Thoughts and comments on the k29 wanted. Thanks!
You have to check and see which turbine wheel is being used to drive the compressor stage. If you have the larger wheel you can step down to the smaller 7200 wheel. Less lag, faster spool up.
i have a K29 but simply have no experience with other 964 turbo's to compare it to! currently sorting out mechanical bugs that came with the car, but no real complaints with it as is.. just down on power til it's sorted unfortunately
