Intercooler Removal
Scott Dunavant (02-09-2023)
I would like to say mine held up perfect for 22 years sitting outside. But the intercooler made it. I use SEM's trim black. Wipe down with lacquer, Scuff with Grey scotchbrite pad, Apply thin coats of SEM's trim black. Touch up when you need to.
thanks @Scott Dunavant . I'm assuming you mean lacquer thinner? is it necessary to remove all the old paint? I'm guessing not - I can just paint on top of the current layers (minus whatever comes off from the thinner and the scotch brite).
Anyone ever remove the shroud?
I was thinking of painting it red like the turbo s.
Fritz
wicks (07-03-2023)
Yes, I already had the fan housing out with the engine in the installation situation. It's a bit fiddly because it sits low and just behind the closing panel but it is possible. The alternator is screwed onto the housing from behind and the cables have to be disconnected. If you have DIY experience on the car I would do it, otherwise leave it alone.
Fritz
Fritz
Clarification. I meant the shroud on the top of the intercooler that is held in by two rivets.
My fault. I already had the IC shroud off, only the two pop rivets on the side have to be drilled out. The inner part of the rivet then remains in the net, you cannot get it out. To attach the shroud you need pop rivets and a rivet gun.
Fritz
Fritz
Be careful not to drill through the core on the inside. It's like 7-8mm away from the outer structure on this Andial S2 intercooler shown on my 91 965. This intercooler barely fits with the shroud and tail seal.
LOMartin (07-06-2023)
I just went for it a few days ago. I was able to remove the inside nub using a rotary tool and time. This will allow me to reuse the same factory hole, after I find the appropriate size rivet.
Now to replace all fuel lines (while I’m in there) and paint the IC shroud red to match my intake I painted during an engine out.
FYI: you can see the paint results on the intake.
paint used was;
Express Paints
- guards red LM3A/L80k/G1
- aerosol clear coat
- aerosol primer
paint used was;
Express Paints
- aerosol primer
How's your a/c clutch? My fiber disk inside the clutch was disintegrated. I need to find a new one.
