Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > 924/944/951/968 Model Specific Technical Forums > 968 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-13-2004, 02:19 AM   #1
gnosis
User
gnosis's Avatar
Default Something's still spinning after I turn off the ignition
When I turn off my ignition, the engine stops, and I hear what sounds like a noisy bearing spinning down slowly. It takes about 5 seconds to stop. I can only hear it if I have the hood up, so it's not all that noisy. It's just that I don't recall it happening in the past. Any ideas what part this might be?
The car has air conditioning, for what it's worth.
Clayton
To remove this ad, register today or login if you already are registered!
gnosis is offline   Reply With Quote
Old 01-13-2004, 09:41 AM   #2
968TurboS
968TurboS's Avatar
Send a message via AIM to 968TurboS
Does this happen when the AC is on? If so, your bearing on the sondensor might be going south. Wait a sec, you are as far south as it goes (AUS), lol.
2008 Porsche Cayenne S, White/Savannah Biege
2004 BMW 330Ci ZHP Converible, Imola Red/Blk
1997 Porsche C4S, Glacier White/Beige
1994 Porsche 968 turbo S, Grand Prix white/Flamenco Red full leather
1994 Porsche 968 Cabriolet, Riviera Blue/Marble Grey
1990 BMW M3 Diamond Schwartz/Black
968TurboS is offline   Reply With Quote
Old 01-13-2004, 10:23 AM   #3
gnosis
User
gnosis's Avatar
I'll have to check and compare A/C on and off. Although my guess is that when I last heard it, the A/C was off.
Clayton
Old 01-13-2004, 10:29 AM   #4
968TurboS
968TurboS's Avatar
Gnosis, there are 2 parts to the AC compressor, one parts that spins all the time with the AC belt and the other operated by a clutch which engages when you turn your AC off.
I get a feeling your bearings on the compressor are making that noise. See if you can isolate the area.
Old 01-13-2004, 11:20 AM   #5
gnosis
User
gnosis's Avatar
Okay. I'm about to replace belts etc. so while I'm in there I'll do some tests centred around the A/C unit.
Thanks,
Clayton
Old 01-13-2004, 01:01 PM   #6
nedkelly
User
Location: Expat Scouser living in Dubai, United Arab Emirates
Clayton,
Check it's not one of the cooling fans bearings squealing on it's run down. You can pull the fuse for 1 fan which will cause the other to go into warp speed and this should give you time to listen to it running down. Replace fuse for fan 1 and repeat for fan 2. It's a 2 minute check and will at least allow you you chalk the fans off the check list. I'm brand new to these cars so I could be talking complete and utter rubbish of course!
nedkelly is offline   Reply With Quote
Old 01-13-2004, 02:22 PM   #7
968TurboS
968TurboS's Avatar
Ned, excellent call. Sometimes the fan can rub against the shroud and create similar sounds as well.
Old 01-13-2004, 08:54 PM   #8
gnosis
User
gnosis's Avatar
Will do. Thanks.
Clayton
Paid Advertisement
Tags
2003, 330i, ac, bmw, car, engine, fan, hear, ignition, jet, loud, noise, off, ski, sounds, spinning, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
