968 Battery
In 2015 I posted this --> https://rennlist.com/forums/944-turb...l#post12697860 <---
This battery is still in use. Until 2017 this small thing started my 944 and after having refurbished my 968, it starts my 968. It's unbelieveable, that this small battery has the power to start a 968 engine. By the way, 26 lbs saved, at least.
jsheiry (03-30-2021)
Lifetime Member
Lifetime Member
FWIW I purchased an Antigravity Lithium-Ion T6 size battery (perfect size for a 944 or 968) for my 1990 944 S2 when they were on sale at 15% discount (still $$$). The T6 comes in 40 or 60 AH capacity. I purchased the 40 AH with 1500 CA. It's very lightweight at 15.45#. It will be installed shortly along with a new 1.7 KW starter from Summit Racing.
Antigravity (04-05-2021)
@Isaacsracing : A little off topic but it's been something I want to put on my car; any chance you can show how you mounted that battery disconnect? Did you use available mounting points, or did you tap and drill something for the bracket?
Cheers
Cheers
Zirconocene (04-04-2021)
Cliff
Some do, some don't and that's not a stipulation in the PCA minimum requirements. While a region cannot allow less than the MRs, they can add to them and that's one of the things that some have added. We do not require it in the region I am Tech Director for, but one of the other regions I run with does require it and in fact, they insisted on adding a piece of duct tape to my cover even though it is the factory cover and snaps into place. Whatever suits them I suppose - just let me onto the track.
Cliff
Cliff
Having just bought a new battery - I ended up with a Duracell made by East Penn for Duracell) from Batteries + Blubs
Duracell Ulta Gold (SLI91T6M) direct fit 3yr warranty with 700 cca and if you bought on-line they have a 20% off
coupon with same day pickup in store...
Sam
Sam
Hey Scott, I had an “opportunity” to try my micro starter for the first time the other day. (Damned dome light!) Worked flawlessly!
Big fan of batteries+ Last time I needed a battery for the 968, they weren’t in stock and with a quick internet search I found out there was an East Penn distributor 35 miles north of me. Same battery they make for Batteries+ for $20 less. Same warranty. Deka branded vs Duracell.
I would of asked for my old battery back.
-Yogii
AKA 968 Novice
dlearl476 (09-03-2023)
Me too, if the shop wasn’t 500 miles away. I didn’t notice it until after I’d driven home. I was so pissed off by the whole affair, I took my car to the car wash, blasted the month worth of mud all over it, and headed home toot sweet.
It's a good thing that shop is 400 miles. Otherwise I might be tempted to return the crappy battery through the front window, Discount Tire-style.
