968 Forum 1992-1995
Gummy Starter Syndrome ( GSS ) Repair
Old 09-24-2004, 12:39 AM
BruceWard
BruceWard's Avatar
I drove about 25 miles in short trips today. The starter performed extremely well on each of the eight starts. The engine feels smoother (balance belt retension) and stronger when cold (fuel check valve).
Old 09-28-2004, 12:05 AM
mwc951
mwc951's Avatar
Any one know if this procedure holds true for the 944/951 starter as well?
Old 09-28-2004, 12:36 AM
BruceWard
BruceWard's Avatar
I found a few pictures and the 944 / 951 / 924 starter appears to have a much shorter shaft and bendix.
You should be able to do something similar with it.
I wonder if 968 Tips have the same starter as a 944? I assume the long shaft and bendix are to compensate for the thick dmf.
Old 09-28-2004, 05:21 AM
NeedPorscheSpeed
NeedPorscheSpeed's Avatar
I agree with Raj, Bruce--excellent write-up! Thanks for taking the time to share your experience with us.
Old 05-23-2010, 11:26 PM
rdhayward
rdhayward's Avatar
Are the photos from this write-up available anywhere?
Old 05-24-2010, 06:41 PM
odb812
odb812's Avatar
I saw a thread started by Bruce Ward and had a bit of deja vu. I doubt those pictures are around anywhere.
On a side note, last time my starter acted up I said F it and just bought a rebuilt one from Sunset. Under $100 with core charge. I think I still have my original starter, all gummed up, somewhere around here.
Old 05-25-2010, 10:50 PM
rdhayward
rdhayward's Avatar
Thanks anyway, odb812, I managed it on all on my own. I did use a small amount of bearing grease on splines and gears.
I would like to add the DIY, as well, with my solution for reassembly of the ring and collar. Once I slid the ring into place and did the best I could to reduce it's diameter with a pair of pliers, it was still difficult to make the collar fit back over it. I wrestled with it a good while.
Ultimately, I put got the ring and collar close together, with a 13mm wrench behind the collar and a 12mm wrench in front of the ring, then squeezed the two wrenches together with a pair of channel-lock pliers. Voila! Snapped right into place.
The starter is much, much smoother than before, and not disengaging.
Quick Reply: Gummy Starter Syndrome ( GSS ) Repair
