968 Forum 1992-1995
Help! Front brake rotors
Old 03-23-2007, 12:09 AM
Lord_Galva
Lord_Galva's Avatar
Default Help! Front brake rotors
Yikes. I thought this was going to be a walk in the park but no. I am attempting to replace the front brake rotors on my 968 but I can't get the Grease cap/Dust cap off. The workshop manual says to use 2 tire irons to pry off. I am using a screwdriver and the nail remover part of a hammer. The thing won't budge. Please please i need advice quick. Also keep your answers "dumbed down" because i'm not very mechanicly inclined. (Had to look up tire iron)
Old 03-23-2007, 12:44 AM
Cervi
Cervi's Avatar
Why would you want to take the grease cap off ? If you're only changing the rotors, take wheel off, unscrew the small screw that just holds the rotor in place, and tap gently (use rubber hammer if you have one) and the rotor should fall off. I just replaced mine today. Good luck
Mike
Old 03-23-2007, 12:51 AM
Lord_Galva
Lord_Galva's Avatar
!!!!!!!!!!!!!!!!!!!!!!! Where exactly is this mircle screw?
Old 03-23-2007, 12:54 AM
Jim Child
Jim Child's Avatar
There should be two small phillips head set screws holding the rotor hat to the hub. Unscrew those and the rotor will come off. You may need some gentle taps as Cervi describes.
Old 03-23-2007, 02:07 AM
Lord_Galva
Lord_Galva's Avatar
You both rock!!! Thanks for your help.
Old 03-23-2007, 10:56 AM
RajDatta
RajDatta's Avatar
Also, there are two M8 threads in the rotor and I always use a cheesehead to screw into the threads. You alternate between teh two threads. This forces the rotor away from the hub. Does the same thing, but there is no hammering involved.
Raj
Old 03-23-2007, 11:15 AM
flash968
flash968's Avatar
as to the original question, since it is a good idea to repack the bearings while you are in there, to get the cap loose if it's really stuck, at the top where the cap meets the hub, squirt some tri-flow between cap and hub - use liberally - let it soak
then, get a good drift, set it on the lip of the cap, and tap the cap off, working your way around the diameter in a criss-cross pattern, a little at a time - be patient and work slowly around
Old 03-23-2007, 11:32 AM
stolarzj
stolarzj's Avatar
To add to this, I would recommend a brass drift so you don't mar the aluminum hub..
Old 03-23-2007, 12:51 PM
flash968
flash968's Avatar
yup - that's what i use - i should probably have clarified that when saying "good" - thanks
Quick Reply: Help! Front brake rotors
