968 Forum 1992-1995
968 missing when cold
Old 04-25-2011, 10:30 AM
keske968
4th Gear
keske968's Avatar
Default 968 missing when cold
I have a 1994 968 with 142,000 miles on it. In the last few months it has started missing when the engine is cold. After it warms up it smooths out again. I have changed the spark plugs, the spark wires, the coil, the rotor, and the distributor. It ran perfectly for about two days. Now it has started missing again. What else could be going wrong? I do not trust the dealership here to troubleshoot as I started there and everything they did had no effect on the car. If I am very gentle with the throttle until the engine is warm I can usually avoid this problem. However, if I am more aggressive with the throttle (i.e. 3500 rpms) it will start to miss after about 2-3 minutes of driving. Any suggestions?
Old 04-25-2011, 01:40 PM
keske968
4th Gear
keske968's Avatar
I suppose that I should add that the wires were changed about 3-4 months before the rest of it was done. Is it possible that I had a bad coil that fried a wire?
Old 04-25-2011, 03:59 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
computer/O2 sensor related? ? ?
Old 04-25-2011, 06:50 PM
keske968
4th Gear
keske968's Avatar
Not sure. The dealer cannot come up with any fault code. Which computer would it be?
Old 04-25-2011, 08:24 PM
ninefourfourt
ninefourfourt's Avatar
Double check the dist cap to make sure it has no visible cracks in the plastic. Use OEM style plugs, stay away from those 'cool' quad tipped bosch units.
Possible fuel issue (fuel injector) or vacuum leak could be the issue too. Its definately harder to track such things down on an older non-OBDII car.
Old 04-25-2011, 08:27 PM
keske968
4th Gear
keske968's Avatar
Dist cap is new. Could be the plugs I am using the bosch quads right now. I just find it wierd that when I changed the wires it ran fine for a day or two same with the new dist cap, rotor, and coil then it started missing again.
Old 04-25-2011, 09:04 PM
John Etnier
John Etnier's Avatar
Still: check the distributor cap. Pull the black shroud away from the red bakelite body to look for carbon traces.
Old 04-25-2011, 09:47 PM
968rz
968rz's Avatar
A garage should be able to scope the ignition to see if there is an electrical miss but my quick guess from your symptoms is failing head gasket or leaking injector (maybe a vacuum leak, I've seen them happen only when cold).
Quick Reply: 968 missing when cold
