968 Front Splitter, Carnewal vs. OEM?
iPod Tamer
I searched around and couldn't quite figure out the story on the front splitter. I called Sunset and they said that PMNA no longer carries any parts for anything older than the 996. So is it possible to still get the OEM splitter or is Carnewal the best source now? Is it made to the same specs as the OEM version? What is everyone's experience with buying from them?
Is anyone currently using the Carnewall one? Based on the pictures from the website it doesn't appear to be drilled for the factory mounting points. Also, do you retain the batwing?
No it doesn't come predrilled - or at least 5 or so years ago it didn't - the bat wing stays - they recomend that you cut off the tab so it sits flush. I opt'd to cut holes for the tabs at the time I drill the attachment points. I then had it painted and it was easy attach when it was ready....
Sam
Sam
Sam
Sam
iPod Tamer
