Prodedure for testing LSD before a rebuild?
I have a 92 968 with the clutch type LSD. Does anyone know what the procedure is to test if the LSD is still performing to spec, or needs to be rebuilt? I don't want to tear into this trans if I don't have to.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
throw down some dirt and drive over it.
then floor it.
go back and inspect the dirt.
or install a V8.
pull up to a piece of asphalt and drive over it.
then floor it.
go back and inspect the asphalt for rubber fragments.
then floor it.
or install a V8.
then floor it.
968gene, thank you for the link. I got in between 15.5 and 15.8 nm every time. Looks like it has about 20% life left in it. I wonder if I should use the redline 75-90 ns instead of the regular 75-90?
