Just picked up a 93 968 No oil pressure
#31
I took a quick look, for the North American 968s it works out as follows: Coupes with sport seats: 154 Coupes with sport seats and heat: 77 Coupes with sport seats, heat, and the seats are full leather: 4 Cabs with sport seats: 67 Cabs with sport seats and heat: 42 Cabs with sport seats, heat, and the seats are full leather: 1
#34
Remove oil filter, use long funnel and fill up center threaded hole and upper and lower cavity ports with oil till there up to the top and it doesn't run back down fast. Put filter on and start car for a second or two. Repeat a few times if you don't get pressure than you have a major problem with, pump priming
#35
What a place !
#36
#37
Have you checked the torque on the main crank pulley. If it is loose, you will not get any oil pressure. It should be torqued to 155lbs/ft. This would be an easy thing to check and very critical.
#38
I haven't done much of anything yet other than pull the valve cover but will add that to my list today. Thanks!
#39
Ok so I had a chance to look at it, I pulled valve cover, everything looked pretty dry but in good shape, so I put it back on temporarily not paying too much attention to how good the gasket went on, I changed the OPRV with another, it looked fine tho. I put some oil in the filter housing. I cranked it with dme out and wasn't building pressure. Here's what's odd tho, I did fire it up bc it wasn't cranking very fast so I didn't want that to give me a false oil pressure reading. Now, before I put the valve cover on, I put a little oil on the cams. After letting it run for about 5 seconds I shut it down bc the gauge still red no oil pressure but when I removed the plugs I now have oil down there that leaked from the vcg. The top end was much quieter but I assumed it was bc I oiled the cams. But how would I get leaking in the spark plugs with no pressure?
#43
#44
I would assume it' would be an indirect issue if it's loose causing unnecessary vibration which would narrow down potential causes of no oil pressure
#45
The crank bolt tightens the crank pulley against the oil pump drive sleeve. The drive sleeve is not keyed to the crankshaft, it relies on being clamped by the pulley against the crankshaft flange. A loose crank pulley could mean the drive sleeve will slip on the crankshaft.
