968 Forum 1992-1995
Rookie CS steering wheel Question
Old 01-13-2014, 12:40 AM
Copilot
Copilot's Avatar
Default Rookie CS steering wheel Question
Bit of a rookie 968 question for you all - I'm looking a picking up a used Club Sport steering wheel - either a replica or an original. A couple of questions:
1. What kind of adapter do I need to get/use to get that 3 bolt pattern they have to work?
2. What do I have to do/add to the steering column, if anything, in order to get it to work with a non-airbag wheel like the CS? I have the standard airbag wheel on there currently.
3. Is removing the airbag going to set off any warning lights? If so, can those be disabled or am I just going to be just pulling a bulb out from the dash?
4. Anything else I need to know?
Thanks!!
Old 01-13-2014, 12:53 PM
RajDatta
RajDatta's Avatar
I would try the search feature. This has been covered in the past.
Old 01-26-2014, 03:49 PM
Damian in NJ
Damian in NJ's Avatar
In any case, the best and first mod to make to your 968 (along with putting in euro turn signal lenses).
Quick Reply: Rookie CS steering wheel Question
