Introducing Angela 968 Turbo S2
2992cc GT35R double BB turbo
Tial 46mm wastegate
Custom exhaust sectional v-band
Drive by wire
Cool on plug
AEM Infinity-10 EMS
8-1 CR w/oversized valves
Ceramic coated combustion chambers, pistons, valve faces
Ceramic coated 4-1 headers, custom 2.5 inch exhaust to turbo and 3" from turbo back coated up to catalytic converter
4ch EGT +
Tial 46mm wastegate
Drive by wire
Cool on plug
AEM Infinity-10 EMS
4ch EGT +
Have you had a chance to dyno it yet? Be interesting to see how it compares to factory turbo. It looks great!
Any 3.0 turbo, especially the ones with 16 valve heads, it going to easily surpass factory cars by at least 100hp-150hp. I am sure this car can easily make 450hp at 1 bar.
I would say its unfair to compare a factory car to this. Factory had to build homologation specials, keep it under 965, performance wise and use the parts bin. That car had to be limited to how much hp it could make (ADAC rules). It only made 305hp, which is not much when considering it was turbo-charged.
I have 4000+ but the app to display them I haven't finished, but did pic everything. In 9 years I built the engine twice before settling on three as a charm. Everything coated dry film to white lightning, exhaust is coated with white lightning up to the catalytic. Taught myself to weld and built the exhaust starting with an SFR system that fit poorly for the 968. Added a 14" resonator after the cat. and every piece is 3" v-band down to the borla tip.
Originally Posted by 968turbos2
Thanks Raj, coming from you that is a compliment...and....you played a key part in this project, can you guess how?
