DIY guys- how do you get your 981 on jack stands?
#31
Relying ONLY on a jack is a gamble I’d never take. We had one fail. Had been reliable for years and was far more robust than required by the weight of the car. Thankfully jackstands were also in place. No one was in harms way when it failed.
Too risky not to use a proper jack stand. Too much to lose and it takes only a few moments to do it safely.
Schroedinger (11-04-2019)
#32
10X as much as what?
Quickjacks go on sale every now and then for ~$900 or so. Can be used with different cars!
Liftbars are $350 and are vehicle specific. Then add a low height floor jack and jack stands to that. I'm thinking you are closer to $700 min in a liftbar solution. (I don't use cheap stands or jacks PERIOD. It's your life so why would you spend less on a lifetime jack than ONE tire costs?
I should add that I don't have a liftjack. I have a floor jack and jack stands from 20yrs ago, but I'm thinking more and more about a whole vehicle lift since I have storage issues too.
But at some point I'm going to get a quickjack, agree it makes sense just convenience factor alone.
#34
In my post I sounded like a salesman. Sorry, but my QuickJack is one of my favorite tools. I was looking at two post lifts and it is less than half the cost of one of those. It works great for me; I thought I would share. My race car is on it almost every week. I bought the QuickJack because I got really tired of the time it took to put the car on stands all the time. It is really handy for suspension adjustments. I can lift the car, make an adjustment and quickly lower the whole car to check alignment or corner weights. I also do a lot of brake bleeding and pad changes. I'll never go back.
#35
I have the QuickJack too, the 5000SLX. I use it mostly for my 981, but also for our 2 Honda CRV's. I've done oil changes, brake jobs, header installation, tire changes, etc. And yes, it is very helpful for polishing the car. Regarding storage, I push them in from the sides of the car, and "store" them under the parked 981 in the garage when not in use. That way I don't have to haul them around, and they are out of the way, and ready to go when i need them. More than enough clearance that I never have to worry about hitting the bottom of the car.
lottadot (10-17-2023)
#36
Kiznarsh - I have a 987.1 and the 5000SLX works great without any extensions. For some of my cars I add 4 of the slotted "hockey pucks" on top of the rubber blocks that are included with the jack for the pinch welds, but they are not needed for the Boxster. Check out the fit guide: https://www.quickjack.com/support/measuring-guide/I found mine on sale last year at Amazon and got free Prime shipping.
#37
QuickJack was totally worth it. I used 2 ladder hangers each on the wall with a shelf for the hydraulic unit. yes requires a little muscle to lift them but arguably takes up less floor space than my floor jack. For just getting 2 wheels off the ground, setup is a lot longer than a regular jack but for all 4 work its really great.
or
or
#39
Is there anywhere to store the liftbars inside the car for transport? Most of my jacking is at the track and i can see them being a bit of a hassle to carry around and use several times a weekend. They also require a low profile jack and the most common option is the steel 3T harbor freight one. I have that jack, but its too heavy to lift and carry around to the track. What's wrong with the hockey pucks that fit into the car's slots and just jack normally via rear lift points to put stands under the fronts and then the rear center point?
(I just got the car and haven't actually jacked it up yet... heh)
#40
As a fairly new 981 owner, I went through researching the options as well. I've worked on cars and trucks all my life and after my first oil change, I knew I had to get something. I researched options and watched youtube videos, and ended up with the Quickjack. Takes a few minutes to setup, but lifts the whole car to a nice height and gets all four wheels off the ground. I htought this would be nice for cleaning wheels and bleeding the brakes. The one negative is that they do block one from getting under the car from the sides.
Bought my Quickjack at Costco for $999 and bough 4 reverse logic jack pads off of ebay which I think were another $100. The setup works great.
#41
I love 'em in my garage, but I just don't see them as a attractive track-side option.
txbdan (11-09-2019)
#42
new Boxster owner - considering all lifting options
I too am looking for good lifting options for our 2013 Boxster Base, Base should be in all caps . We really like this as our first Porsche, didn't go all in, we'll know down the road what we really want.
I think the lifting and stabilizing of the car is of utmost importance. As a professional tinkerer, I'll definitely be performing a lot of the lower technical maintenance duties (brakes, oil, spark plugs, other bolt on break/fix jobs).
It appears the QuickJack system wins in popularity, would any QuickJack users reconsider? If so, what other method would you have chosen for lifting and jacking?
I'd also like to hear from others that have tried multiple ways and systems that have settled on what their currently doing?
Thanks again all!
#43
I have a set of Liftbars that worked great (I've since sold my car). I looked at Quickjack but it looks to me like more work and more expense vs. Liftbars and jack stands. I'm actually going to list my LIftbars in the Marketplace today.
#44
First post to the forum, I've been reading many posts and most everyone appears to be quite helpful and pass along great info.
Thanks again all!
Thanks again all!
#45
...It appears the QuickJack system wins in popularity, would any QuickJack users reconsider? If so, what other method would you have chosen for lifting and jacking?
Thanks again all!
Thanks again all!
