DIY guys- how do you get your 981 on jack stands?
I’ve been researching this for a while, and I’m getting a lot of conflicting information. There are four factory jacking points, which is where the jack stands need to end up. Seems that jacking the rear underneath the sway bar mounts is also safe. So it seems like the order of steps that makes sense is:
- jack the entire driver side up from the rear jack point.
- put the front jack stand under the front jack point.
- release jack, move to drivers side sway bar point, lift a little and put 2nd jack stand under rear jack point.
- repeat steps on other side.
Anyone care to share their sequence of steps? Thanks in advance.
Do a YouTube or google search on “ RennStand:
Also, search Jack Point jack stands.
http://www.jackpointjackstands.com
Schroedinger (10-21-2019)
Thanks for posting. I have seen both of those products/videos; look nice, but is there any way to do it without Porsche-specific jack stands? They’re not cheap, and it looks like they don’t get the car very high off the ground.
Didn't really wanna spend the $$ on the Rennstands but in the end, seemed the safest and easiest way to go. Some pics here from when I was jacking up and removing all 4 wheels to coat them: https://budgetplan1.wordpress.com/so..._Detail_Wheels
Some folks do indeed jack from central points, some company out there (fabspeed) makes something that bolts to central rear suspension point to be used as jacking point but opinions vary and ultimate appropriateness seems to be up to the individual:
There is another company that makes frame rails for jacking as well, (liftbars) was slightly less expensive than the Rennstands:
The following 3 users liked this post by garfunkle:
My current recipe for success...
1 set Liftbars + 1 very low profile floor jack + 2 sets of jack stands = most complete and safest under-car set-up I've ever had short of a professional lift.
If you go this route, be sure to get the type of stands called for on the liftbars.com site (they fit the bar, not the car). The pic above shows flat-top stands, not for use with liftbars.
Of course, one must follow all instructions and safety procedures.
I like this set up as there is no guessing at "alternative" lift points, no bolt-on adds to the car, uses only the factory lift points as designed by Porsche.
I use them now for everything requiring under-car work. Wish I had found them sooner. Would have saved a lot of time and hassle.
It was an investment, likely about $400 all in. No commercial interest, just a happy customer.
Good luck!
- Lift bars come from http://liftbars.com
- I think this is the jack I use (3 1/8" at lowest) https://www.harborfreight.com/3-ton-...ump-64264.html
- Bought two sets of these (want matching stands for perfect height) https://www.menards.com/main/tools/a...8381147&ipos=1
Good luck!
The following 2 users liked this post by Dave in Chicago:
BudgetPlan1 (10-21-2019),
https://www.planet-9.com/threads/get...-stands.84777/
Yup, this is how I do it: (Reference link has already been mentioned in earlier post)
Summary:
Now the car's up on 4 jack stands. I always test with some pushing and shoving to make sure it's stable. I also leave the wood blocks under the rear wheels and the jack contacting (but not load bearing) the rear sway bar jack point as emergency supports if a jack stand should fail (has never happened so far).
Standard disclaimer about how you'd be foolish to take my advice and should thoroughly research this before attempting to do yourself. Never do anything you're not completely comfortable with. Nothing in this post suggests or recommends that YOU should do this; this post is merely a description of what I do.
Summary:
- Set parking brake. Chock passenger side front and rear wheels.
- Jack driver's side from rear jack point.
- Place jackstand under driver side front jack point.
- Place 4x6 wood block (2 pieces of 2x6 put together; use 4" side) under driver's side rear tire.
- Release jack from driver's side rear jack point.
- Move over to passenger side and lift from rear jack point.
- Place jackstand under passenger side front jack point.
- Place another 4x6 block under passenger side rear tire.
- Release jack and move to rear jack point at sway bar attachment. Lift from there til rear wheels free and place jack stands under rear jack points.
The following 2 users liked this post by DrBillyD:
pedal bliss (10-19-2023),
From what I can tell the Liftbar setup probably meets my needs the best. I already have a low profile HF jack and four axle stands. The bars themselves are decently priced, and this setup would let me get the car pretty high in the air if necessary. Thanks all!
No guessing at "alternative" lift points, no bolt-on adds to the car, uses only the factory lift points as designed by Porsche.
Good luck!
Good luck!
Good luck!
I did the full Monte and bought a set of QuickJacks. They're more expensive for sure, but IMO they are by far the safest solution (short of a real lift) and require the least effort.. Besides, it doesn't take very many oil changes to justify the cost of the QJs as compared to having an independent (much less a dealer!) do it for you.
For most of the jobs I want to do, ramps aren't ideal. First issue is that the wheels need to be on the car, which eliminates brake and suspension work. Second issue is that the whole motor is tilted, so even for oil changes it's hard to get the whole pan to drain. They are a lot more convenient though!
cavediver32043 (11-08-2019)
