981 Apple CarPlay?
981 Apple CarPlay?
Apologies if addressed, but haven’t found any information in searching ...
Has anyone confirmed aftermarket functionality of a CarPlay capable head unit in a 981?Looking to add a Kenwood or Apline unit, and would assume a harness adapter exists, but can’t get any reputable outfits (Crutchfield, etc.) to confirm.
Any input is much appreciated.
Hi,
Not done it myself but there is options to add CarPlay /Adroid Auto to the original unit.
Found the thread on Porsche GB and also seen it on Porsche SE.
https://www.porscheclubgb.com/forum/tm.aspx?m=1009017
and link to one of the vendors, this there is on Ebay aswell.
https://www.nmautomotive.co.uk/carplay-androidauto
Hi,
Appreciate the link, though!
Thanks. Unfortunately, my GT4 didn't come with the PCM 3.1 unit with NAV and iPhone AUX capability, so I don't think that kit will work. Hence my looking to replace the head unit altogether with something that I know has full wireless CarPlay functionality.
im in the same boat as you, I bought a PCM off eBay. And I’m going to try and install that. I like the look of OEM.
I am looking for the same solution for wife’s Boxster with a base CDR, no NAV unit. A head unit replacement with Apple Carplay is easy, there are a lot that will fit but getting the steering wheel controls to work has been the stumbling block for me. I have not found an adapter or script for the existing adapters like iDataLink Maestro that support Porsche.
The UK solution referenced above does NOT work with CDR. I emailed them and they confirmed it only works on PCM cars that have NAV and MAPS functionality.
When i contracted the folks in the uk they said they could not ship to us. Not sure if that has changed but please keep us apprised if you find a solution. I suspect many of us are interested and if they are like me have just given up
My '18 Camry didn't come with CarPlay but instead used a crappy proprietary system called Entune. It sucked. In response to owner complaints, Toyota developed a software flash that added CarPlay and charged a whopping $60 for it. Gotta love Toyota. They all could do it. But they don't.
Addict & Guru
I replaced the oem (US) base GT4 head unit with a Kenwood DNX995S head unit including Garmin Nav, Car Play, HD radio, Pandora, etc. and both front and rear cameras. Mine was professionally installed so I can't help with the level of difficulty. Obviously, it can be done.
Given the ambient noise level in a GT4 I left the oem speakers. Very pleased with the result.
Not spoken to these ppl, but what I can´t find anything that it should not work.
https://www.naviplus.com.au/online-s...kage-p91428805
https://www.unichip-tec.com/Porsche_...e_CarPlay.html
Is the CDR version not a PCM 3.1 system ?
Thanks!
