981 GT4 CS Track Oil temp
I'm getting oil temps upwards of 275/280 within about 15-20 min in a session and water temps of 220 or so on hot track days at Sebring in the summer. I know Porsche says oil up to 290 is ok, but that seems a little nuts (and they need to sell engines...). Has anyone tried an additional or larger oil cooler? Any suggested products? Just having more mass/volume in the system should bring temps down. What is the ideal oil temp for GT4 and C4 engine?
A few thoughts and things I've tried (would welcome feedback!):
1) 98 octane helps
2) anyone tried a real race oil with more zinc (amsoil or similar)? I've got headers, no cats.
3) I need to be able to run water (no coolant) for races; any "race approved" additive suggestions?
4) it does cool down very quickly within a 1/4 lap if you lay off and short shift for just a few turns, so the system clearly works well.
I find it hard to believe that a 2 or 3 day weekend of hard running in the summer heat at 275+ wouldn't be an issue for the oil.
1) 98 octane helps
Get your oil tested and find out for sure. I've done up to four track weekends hitting 265Fish on Driven DI40 and the oil analysis came back great. No loss of viscosity, no wear, plenty of additives left.
In the August 2016 issue of Panorama, there was a discussion with the director of GT4 ClubSport development that indicated the Porsche was not concerned with oil temps as high as 290F in 73F ambient temps racing in the GT4 ClubSport, which has the standard GT4 cooling system.
Turboale (06-17-2021)
290 at the sensor is what at the mains and rods? I would consider a deep oil sump which seems to help a bit. Porsche lies, so I'd want those temps as cool as possible.
1) 98 octane helps
1) 98 octane helps
I am trying to deduce what else to do or check.
The oil temps you're checking, are those from the dashboard display, or are you looking at the CANbus sensor values? I ask because (assuming the ClubSport is the same as the base) the value displayed on the dash is a combination of several different sensors, and blends the PDK oil temp with the engine oil temp.
It would be interesting to see the CANbus readings from all the individual temperature sensors on both cars during that run to see if your cooling system was fully heat-soaked and couldn't get the coolant temperature down low enough to pull down the oil temps. Running in traffic also drives up coolant/oil temps vs. running in clean air.
You indicate you have added headers with no cats. That gave you extra HP and extra heat. Wrapping your headers is another relatively inexpensive option I get similar symptoms with my 981 S PDK but 280 is the highest I've ever seen. Like yours mine will quickly drop during cool down. Short shifting with the paddles helps. My water temp gauge never moves off of 194 so I have always suspected the capacity of the oil heat exchanger followed by the PDK cooler. The GT4s have a larger oil heat exchanger already. Believe you can get a larger PDK cooler that would indirectly help the engine oil temp.
The AC condensers obviously restrict the air flow. There is a thread with a full race 987.2 chasing a GT4 that has great oil temps, but he has no AC and upgraded to all of the GT4 cooling bits plus an added large PDK and diff cooler.
I have seen threads where Porsche and Mobil 1 were not concerned with temps at 280-300. As already stated doing oil analysis to determine if you are getting viscosity breakdown should be done. .
Did you have a tune when you added the headers? If you did I'd have a conversation with your tuner if they had any experience with controlling oil temps without sacrificing HP.
Most of us mid engine guys worry about oil temps, so keep us posted.
*an MR Evo, but the MR and Evo packages don't touch the power unit.
Updates - I do have A/C, so the condensers may be impacting airflow. I'm not sure where the oil temp reading is coming from, but I have a motec dash. It routinely shows a much lower temp than the stock dash, so I assume it is a true engine oil reading. My stock dash shows warning lights pretty much every session, so I just watch the motec. Higher octane definitely helps, and I don't have a tune on it.
1) 98 octane helps
1) 98 octane helps
