How long does a stock battery last?
I have a 2013 and noticed recently when I was doing some testing with my stereo with the engine off the battery drained very quickly. I’m thinking I may need a new battery but curious what the avg lifespan is.
My '14 CS will be 8 years old in Sept. Still on the original battery and seems to be doing fine. It's on a battery tender during the winter months when driven infrequently. That said, I wouldn't think you've done too badly if your '13 needs a battery soon.
my 981 was built in 2/2013 and it still had the original battery in June of 2020 when I changed it. The Auto/Start/Stop function had stopped working with the original battery, but it always started.
did you change it preventatively or because the start/stop wasn’t working?
Other things:
Tires: 6 year max, regardless of treadwear
Serpentine belt: 5 years
Everything else, I follow manufacturer maintenance schedule.
Premium Sponsor
The thing that will dramatically lessen the life on a Lead/Acid battery is allowing the battery to drain dead a few times. That damages the Lead/Acid battery and really diminishes the life span. So try to not allow it to drain below 11.5v much just to be safe. Deep Discharges into the 6v and lower range really shorten the lifespan dramatically.
2014 Boxster S changed it a couple months ago at 17K miles when autostop/start would message as not activating in dashboard and occasionally seat would not stop at the correct position.
Car otherwise drove fine but decided that was pushing it far enough and didn't want to get stranded (AAA or not).
I changed the battery in my 2013 BS after seven years. The only symptom I had was that was that the start/stop worked only periodically. Other than that no issues. No hesitation starting even when temperatures fell to the single digits. My view was that it was better to change the battery a year early than a day late.
