Backup Camera Wiring Question
I’m installing a wireless backup camera, and need help on where to wire it in so that the camera only turns on when reverse is selected. Instructions say to attach to wires to backup light, but I can’t see where to access them I have found a fuse panel in front of the passenger side tail light assembly which seems like a likely power source, but can’t find a fuse diagram that even mentions that unit.
I am not so sure you will find the power source you are looking for in that rear fuse panel. In the owners manual it lists the fuses in the left footwell row B2 as right reversing light and row B4 as right reversing light (probably one should be left). Each fuse also powers many other interior and exterior lights. I think you will probably have to go to a wiring diagram to find the wire you need to tap into???
Jim
Jim
Location: South Louisiana, Bonfire Capital of the World
Likely that you'll need to tap into the wire from the reversing light terminal of the Rear Body Control Module (BCM) under the driver's seat. Or you can go to the rear of the car where it goes into the backup light, or find that X250 connector.
Jim981CS (08-01-2022)
Thank you both!
YouTube shows a 10 minute connection to the wires to the backup light in a Camry. I figured I could tap into the Porsche backup light wiring, but can’t even find it…there has to be power to our backup LEDs somewhere, right?
At this point, I’d be willing to connect to a full time 12 volt source without having to wire the car from the front fuse boxes…that’s why I chose a top rated “wireless” camera in the first place!
There must be a 12 volt line in the rear fuse panel photo I posted that I could use, even if it means giving up on the “reverse only” backup camera.
I confess to being an electrical moron (electrons are involved, right?), so I need simple, basic help. “Cut the red wire. But before you do that….” That’s where I am 🙄
Copy/Paste or provide a link to the specific instructions you're dealing with. Sounds like you need a 12V signal when reverse is selected. Looking in the fusebox will only get you constant 12V power.
I tapped into the wires here - but don't recall the colors.
To do it as per the instructions, you need to get on the BLU/BLK wire. Should be blue with a small black stripe. See below for connection points. Highlighted is the wire that sends the 12V to the rear backup light. The connector at the light assembly requires removing the rear apron per the service manual. Connector X250 looks to have 14 total pins on it after searching the wiring diagrams, and is for all things that likely require rear apron removal, so I assume that it is back there, but it may be in the rear luggage compartment somewhere. Easiest access may be identifying the rear BCM under the driver's seat and finding a BLU/Blk wire at connector point 2 of the "B" multi-pin assembly.
Great! So if I can find a Blu/Blk wire somewhere in the rear wiring harness, I should be good? Will I still need to supply electrons or something?
Just kidding 😊
I really appreciate everyone’s help on this forum.
And may have to drive to “The bonfire Capital of the World” to finally get this sorted👍
Just kidding 😊
After more reading, personally for myself, I wouldn't mess with the Rear BCM for fear of creating trouble for myself. Proceed with caution if you plan to go that route.
Last edited by thecajunboy; 08-02-2022 at 12:29 AM. Reason: corrections and additions
Good idea! Where did you connect to the fog lamp?
I am installing an Auto-Vox CS-2 Digital Wireless Backup Camera Kit, which includes its own LCD monitor. I previously tried a system that used my iPhone, but found it was unreliable and slow to connect. This unit has a camera which needs a 12 volt power source, ideally near the rear license plate, and has an antenna to communicate with the monitor.
