Power windows inoperable
Hi Guys,
Im after some help/ guidance. We have just replaced a drivers side window switch assembly on a 2014 981 Boxster S due to one of the buttons coming loose. The windows did work prior to removing the broken switch block. Part number 991 613 151 02 DML.
Now upon putting the new switch in we now have no activations via this new switch, windows or power mirrors. We have checked the fuses and all seem to be just fine.
With our durametric I do get a fault code for Door module Front Right (drivers side as we are in Australia). Fault code is 2111 Motor for power windows/ incorrect coding/ calibration.
We then tried to put the old window switch block back in to see if this would work again and it wouldn't
Has any one had a similar issue to this? any work arounds
Regards
Sean
Regards
Sean
