Is drop link a one time use bolt?
I don’t know if it’s a single use bolt or not, but PET indicates it’s part of the drop link.
If #2 is, then it makes sense that #3 is also.
Where do you find info on what is single use or not?
The service manual might list them (and the pinch bolt) as "should be replaced" or whatever. And if replacing them makes you feel more comfortable then by all means do it. But none of that hardware is actually single use.
I suspect (but cannot prove) that Porsche just tells you to replace any bolt that requires threadlock. A lot of the bolts come with a pre-applied blue threadlock patch on them: it's a way to ensure that the threadlock can't be forgotten in manufacture or repair. So they specify to use new bolts to ensure that the threadlock is always fresh and present. In reality those patches can be used multiple times, or you can just add a dab of fresh threadlock. So I think this is just a CYA thing in the manual.
TMc993 (03-11-2024)
Pretty much. The only fasteners that definitely need to be replaced are ones that are torque-to-yield, and those are pretty rare.
You can reuse it. The bolt is attached to the link. I bought new links so I have a new bolt attached to it and a new nut. But I would have had no issue using the old one. I just put new when I installed my X73. Links are not expensive.
Location: South Louisiana, Bonfire Capital of the World
Technical Values in the service manual do not have any replacement information for the nut. "Replace Following Removal" appears to be the normal text in the tech values when new fasteners are required. Here's the information for that fastener.
That's not a bolt. Or at least not in the traditional sense. It's part of the ball joint for the sway bay link. I don't think sway bar links are one-time use items. Sometimes things get lost in translation when crossing the Atlantic ocean. Europeans often say "replace" when they mean "put it back where it was", Here in the USA we hear "replace" and think "throw away in the trash and put a new one in".
These torque specs are why I was thinking it is a one time use bolt. Anything that has an initial torque setting then an final tightening in degrees, is usually considered "Torque to yield", which means you need to replace it after removal.
TTY bolts do use torque plus angle specs but that's not exclusive. That style of torque spec is pretty common now because it creates more consistent results than a higher static torque value. Note that the other end of the link also uses that style of torque spec, 30ftlbs plus 30*, which experimentally works out to about 60ftlbs which is pretty much exactly the "standard" torque spec for an M10 fastener.
