981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
2014 Cayman drain plug tool?
Old 02-01-2016, 11:49 AM
Han Solo
Han Solo's Avatar
Default 2014 Cayman drain plug tool?
So the dealer said "if you're going to change your oil, buy the correct tool". Here's what I'm seeing. Does anyone have a name for the bit or a part number?
Old 02-01-2016, 12:24 PM
981spyder
981spyder's Avatar
8mm allen key or socket, make sure you push it all the way in.
to remove oil enclosure you need a 74mm oil wrench, you can them cheap at amazon or ecs tuning.
dont forget to replace washer and oil the rubber seal.;-)
Old 02-01-2016, 02:05 PM
MJBird993
MJBird993's Avatar
Did they do this to keep the monkeys at Jiffy Lube from screwing-up our cars?
Old 02-01-2016, 05:52 PM
Han Solo
Han Solo's Avatar
8mm allen will eventually strip it. That's what I used until an over-fill situation forced me to take it to the dealer. There's got to be a special tool for correct fitment.
Old 02-01-2016, 06:30 PM
ECS Tuning
Former Vendor
ECS Tuning's Avatar
It is indeed intended for an 8mm allen socket. Use a quality socket without rounded corners. My Snap-On 8mm is a nice fit.
Old 02-02-2016, 12:04 AM
zadar
zadar's Avatar
They did it for you, so you don't leave oil drag plug on some curb or rock
Old 02-02-2016, 10:17 AM
Han Solo
Han Solo's Avatar
Okay. I'll try a better socket. I got called out on another forum for questioning the 8mm fitment but the plug appears to have a different pattern to me. Perhaps a call to the Porsche service department is in order. After all, they're the ones that said I was using the wrong tool
Old 02-02-2016, 10:36 AM
Han Solo
Han Solo's Avatar
Confirmed 8mm hex tool is the correct tool from the certified Porsche mechanic. Apparently my techniques are sub-par or my bit is toast. End of discussion.
Old 02-03-2016, 12:05 PM
GrantG
GrantG's Avatar
Received 4,739 Likes on 2,701 Posts
Here is the best German oil filter socket:
Amazon.com: Hazet 2169 Oil Filter Socket - 14-flute, 74.4mm: Automotive Amazon.com: Hazet 2169 Oil Filter Socket - 14-flute, 74.4mm: Automotive
And here is a good quality German bit (3/8" drive 8mm hex) for the drain plug that won't round (recommended to change drain plug frequently as added precaution - they are cheap; and crush washer every time):
http://chadstoolbox.com/2050008-stah...x-sockets-8mm/
Also, the torque spec for the filter is 25Nm (18.4 ft-lbs) and the drain plug is 50Nm (37 ft-lbs)
Old 02-03-2016, 12:14 PM
skuplist
skuplist's Avatar
Will this work on any of the 981's? I'm waiting on the Spyder.
Old 02-03-2016, 12:15 PM
GrantG
GrantG's Avatar
Yes. I use them on GT4, but they're all the same.
Quick Reply: 2014 Cayman drain plug tool?
