Knocking from behind driver (RHD)...
Old 08-06-2009, 07:31 AM
Christian S.
Lifetime Member
Christian S.'s Avatar
Unhappy Knocking from behind driver (RHD)...
I wonder if anyone has had a similar knocking/rattle experience to this and could advise? Picked up an early 05 Boxster a month ago and proceeded to drive 3281 miles around France with it. Great fun and very happy with the car.
However on returning to the UK the car has started to develop a variable knocking sound that seems to be coming from behind the driver's seat (RHD). At first I thought it might be something loose in the door, but it has become louder and seems more rearward. It's a variable knock, that can be generated by poor surfaces, but does not seem directly linked to the suspension. It's also fairly low frequency and becomes less distinct when speed rises (due to overall noise).
It seems to be there regardless of the hood being up or down - although inevitable with the hood down, there's more general noise.
I'm about to attempt entry into the innards of the engine to see if anything has worked loose, but superficially, everything seems secure.
Old 08-06-2009, 10:21 AM
cviles
Unique Title
cviles's Avatar
It could be one of the control arms on the rear suspension. The bushings get worn and need to be replaced periodically. I had a similar noise on my '05 and the dealer replaced the arm under warranty and fixed the noise, so I can't give you an estimate of cost if that's the problem you have.
Old 08-07-2009, 06:38 AM
Christian S.
Lifetime Member
Thanks cviles - I'll get it up on the jacks and have a look at that - maybe swap both sides out while we're there.
Old 08-21-2009, 05:15 AM
berty987
7th Gear
berty987's Avatar
Does the car have the optional PASM ? The shocks can be prone to wear giving this noise.
Old 08-24-2009, 04:05 PM
Christian S.
Lifetime Member
No, it's standard I'm afraid. Interesting though, as the sound has got steadily worse and is a constant feature now - sounding more "spring like" ie. a tension sound - I wonder whether the top mounts are prone to wear?
Old 10-06-2009, 06:00 PM
litteng
litteng's Avatar
Default possible known problem
i assume from you posting that you have a 987 model, but you state no information regarding mileage.
there is a tech bulletin issued regard a piston knocking which occcurs in the oil pump.
my car was doing as it was warming up and rev's were between 2 - 3000 rpm.
dealer repair under warranty in my case, problem banished
check to identify when it occurs, then talk to the dealer...
Old 10-06-2009, 06:08 PM
Christian S.
Lifetime Member
As stated in my original post, it's an early 05 model - 987. Mileage is 40,000 , however it has spent most of it's life in Edinburgh, in the New Town where the streets are still cobbled. Definitely a suspension related issue - happening regardless of rev range.
I'm about to take it to an independent shop, hopefully they will be able to diagnose and repair it using experience, rather than my guesswork! Thank you for the suggestion nonetheless.
Old 10-06-2009, 06:41 PM
ricster
ricster's Avatar
My guess its the intermediate shaft about to go south
Old 10-11-2009, 07:49 PM
tinman
tinman's Avatar
what would the IM shaft repair cost in USD$, and can you give some background about, how, when, why.....
thank you
______________________
Howard L.
Quick Reply: Knocking from behind driver (RHD)...
