987.1 Cayman S ticking
Hi All. Kindly soliciting opinions. I know that 987s are ticky engines, and that there are lots of posts about ticking, but this ticking is new (and loud) and I haven't found any previous posts that seem to make sense for this. Also situation is a bit unique as described below.
This is a 987.1 Cayman S with about 70k miles. It had bore scoring, which was fixed by a Porsche independent shop less than 100 miles ago (engine out, new liners, etc). The only place it's really been driven since the engine out is back from their shop. Shortly after I got the car back it started making a loud ticking noise. I've sent the below video to the shop, and they said it sounds like a bottom end bearing failure (but would have to check), which would require a full engine rebuild and since it's not related to new liners they put in it wouldn't be under warranty. They suggested I don't drive car and tow it back to them. Needless to say two engine out services a few weeks apart is going to be financially troublesome.
Thought I would check with you guys on the interwebs to see if anyone had any thoughts? Video to link below. The noise it the same if car is cold or warm. Obviously ticking increases frequency with engine rpm.
https://youtube.com/short...ex4-O2o?feature=share3
Just reading your description of events, I'm thinking, why were the main end bearings not replaced? When I was investigating the options of bore score, thats one thing that was mentioned to me, if the engine is being broken-down make sure you do the end bearings. That was just by a collegue at work who'd had porsches and spoke to his mechanic friend for me to get some Autodata. Surely the Indy should have suggested those bearings were done as a matter of course?
Probably should have. I don't think it was suggested. That being said, I had told them I didn't want to spend more than necessary. I'm in a stupid cancer battle and not able to work much anymore, so money is an issue. Just wanted to fix car so I can sell it to help pay bills.
Assuming you still trust this shop, I would let them listen to it, using a mechanics stethescope, to hopefully isolate where the noise is coming from. Remote diagnosis based on a phone video from the cockpit is not really a good idea but in general, based on the sharpness of the tone, I don't hear bearing. There are multiple things it could be. If you can, you might want to get someone besides the shop that may have screwed up your engine rebuild to listen to it. If I had to guess I would say hydraulic lifter.
Are you in the UK? Is so, send your video to Hartech.
They machined the block. These engines aren't known for bearing failure afaik. Sounds like they ****ed up if the bearings are somehow bad a few miles later.
Don't dismiss the obvious, could be a loose exhaust header bolt. They should be retorqued after a few heat cycles.
ekam (06-18-2023)
Exactly, could be something pretty minor. To me now I've listened to the video, it sounds like its coming from the area where the brake vacume pump is located. Get it to a shop who will hopefully have good news for you, all the best.
From your original description, it seems the car had been sitting a lot and not driven
In my case, it's always a stuck lifter. I drove 10-15 minutes and the ticking goes away. I know this because my car sits for very long periods of time
Good luck
Good luck
emjohn43 (04-07-2024)
