What's going on with my 3.4 engine?
Yes, they recommend something called Driven 40 that has some sort of slippery additive in it. Doubt I'll try that. I know what needs to be done. Well, sort of. I'm leaning towards LN's nickie cylinders and their super-duper ultimate IMS fix. But I do have a couple questions. Back when my son was doing moto-cross, it became apparent that some people were having their cylinders recoated with Nikasil. I looked it up at the time and one place was in Montreal. I wonder if they could do it and if the Nikosil can be applied over the Porsche cylinder base metal. I know they do motorcycle cylinders and outboard motors too. I must look them up and ask them.
The other issue we commonly see are bores that are improperly honed (too rough) which will result in the engines losing ring seal and consuming lots of oil in a very short amount of time. Unless you own a profilometer and know what the finish should be, you really don't know if the cylinders have been honed properly.
Also, are Porsche piston rings designed for Lokosil compatible with Nikosil?
I've been rebuilding all kinds of engines for a very long time, but admit the M97 has some weird quirks, such as installing the opposite bank wrist pin clips and cam gear timing. Then there's torque specs I don't have. There's a lot of info out there, but I wish I had a good Service Manual to follow.
https://lnengineering.com/catalogsearch/result/?q=tkg
https://lnengineering.com/education/...brary/m96.html
The following 2 users liked this post by Charles Navarro:
cavediver32043 (10-11-2023),
SeanPatrick31 (04-13-2024)
It's been a while, but today I finally got the Bank 2 Cyl. Head off and here's a pic of Cyl. 6 scoring. Should have the block split open by early next week. Now to figure out where to send it. I have been looking at the Canadian Rep for Hartech, but their website is mysteriously gone. I must call them to see if they're still in business. LN would be nice, but it involves sending the block halves across the border which means numerous transport changes and that means risk of damage. Just in a cardboard box? Maybe plywood and angle iron.... Anyway, just how much should one insure it for? Probably the price of a whole used engine... maybe $10K ???
By the way, many thanks to Harvey Ferris as he's been a great help with lots of technical info and advice.
The following 2 users liked this post by Eggbert:
harveyf (04-11-2024),
SlakkerRacingDev (04-11-2024)
Since you're in Canada, it's not convenient to have us send our custom block boxes to make shipping easy and safe, but we still have lots of people make it work.
What we used to tell people to do is to use a double wall box and box each case half separately with at least 2-3 min inches of rigid cardboard on all sides of the case half. Any studs and locating dowels need to be removed or they end up bursting through the box. I'd insure each box for market value for a used block - the last two used 3.8 blocks we purchased we paid between $3-4k ea. If you really want to cover your butt you could insure it for the cost of a new block from from Porsche.
Do not put both halves into one box and for sure do not put anything else in the box with a case half like the IMS shaft or anything else for that matter. You'd be amazed how people send their blocks to us and how much shipping damage repair we have to do. :-(
