Please help with troubleshooting some codes
#31
I know some think that cats are the spawn of the devil. That said, the Porsche engine management system uses the information from both the upstream and downstream O2 sensors to make critical decisions regarding fuel mixture. You especially don't want your engine to be running too lean, which tends to generate excess heat. It has been postulated that high oil temps can aggrevate bore scoring due to visocity issues. And if you ever plan to sell the car, particularly to folks in CA, the cat system will need to be functional. I can only assume that the Softronic race tune uses a fixed fuel map for all modes of driving, allowing the cats to fend for themselves or be removed entirely. Just my 2 cents worth.
#32
Premium Sponsor
Best,
Scott
Softronic - Porsche Performance Software Tuning
Faster than a speeding bullet.
Cayman | Boxster | 911 | Cayenne
Like us on Facebook for updates and promos
24HRS Daytona Winners programmed by Softronic!
Porsche Interseries programmed along with teamed owned Tudor and World Challenge cars in an exclusive with Softronic.
Porsche PCA racing binary check by Softronic for compliance.
harveyf (10-29-2023)
#33
The primary o2 sensors are what actively monitor the fuel burn and not the secondaries or post CATs in which purpose are to monitor the CAT efficiency. A race tune does not change the primaries use yet just the secondaries so that a CEL is not generated and the race car owner would then know if there was an issue without having the CEL on all the time when the CATs are removed. The Race file will not pass emissions either so properly functioning CATs would have to be used and either an emissions file or the original. The assumption that a fixed fuel map is used is incorrect.
Best,
Scott
Best,
Scott
Have you ever heard this story?
#34
Premium Sponsor
Best,
Scott
#35
UPDATE:
Replaced the crankshaft position sensor, AOS, and put that mini-cat device on the o2 sensor that's before the cat on bank 1.
started car, cleared the codes that were stored, went for a 45 mile, very spirited drive, NO CODES!!!!
Also, I was getting around 13mpg, today it was 19.8mpg!
Thanks everyone for all the help!
