Really turned off ... Good bye Boxster
I'm really fed up with my flat tire situation. I've had my 4th flat tire last weekend. This is the 4th in one year i owned this car. There is no spare in the Boxster, and every time i get a flat, it's within one inch to the edge, so it's not repairable. I'm tired of waiting for tow, getting towed and buying new tires every time.
Plus I hate the audio system. It skips playing cd's. It doesn't play mp3's. Ipod connection is a science project of its own.
As you can tell, I'm over the "honeymoon" stage with my car, and into the "complaint" stage
I think I'm selling my boxster s and getting a bmw 335 with run flat tires.
At the risk of jinxing myself, I've been driving for over 40 years and I've never had one flat. Why are you getting so many flats??? As far as the radio is concerned, I agree with you, but I knew that going in. If the radio bothers you that much just get an upgrade.
I have dealt with two tire issues in my 996. I am not giving up a car for tire issues, so what I would recommend is you go get 17" wheels (which I believe work on the 987). 19" wheels provide NO benefit for street driving (or arguably track). 18s provide little benefit for street - so get 17s and enjoy pothole protection.
On a side note - the 18"/19" tire options available on the 997, and no spare, are definitely making me think twice about it as my next car....
Originally Posted by pl
wait until you need to replace a run flat.
better yet, test drive a run flat......
When I run tours, I always have to give the speech that PUBLIC ROADS do not have aprons like race tracks... If you ride the outside or cut corners you stand a chance of getting a flat or worse, a bent wheel... Even after the speech I have video of participants trying to cut the corners... Common sense must prevail...
I run my routes 8-10 times before I take anyone out on the run and I've been doing this for 10 years without a flat...
It's not the car... Believe me... More than likely driver error
My guess is you will have the same problem with the next car... You will just be stuck on the side of the road changing a tire...
Thanx everyone for the comments. I guess i just wanted to vent. I drive my car to work everyday. I've already got 17k miles on it ( in one year ). I have no idea why i'm getting so many flats. I owned my previous car for 5 years, and I had only one flat i can remember of. I have not changed my driving habits since then.
I don't take it to tracks. This is happening in the city. Last two times i caught in bad timing so i couldn't get the tire protection plan, this time i bought two tires from big'o'tires and they were able to offer tire protection.
By the way all of the 4 flats were on the rear tires.
1. Switching to 17 inch tires means i need to replace the wheels as well, right?
2. Could you elaborate on the "cutting the corners" ? I don't understand what you mean.
Thanks again.
Thanks again.
Originally Posted by vladie22
why would you get rid of a car because of flat tire issues ? get the tire insurance at the dealer , or buy run flats , but don't blame the car .
Originally Posted by 99firehawk
run flats do not mean that you can just ignore flat tires
Do you guys believe run-flats are useless?
runflat tires are available in a variety of sizes,includeing those that will fit the Boxster wheels . i am assuming you have the 18' wheels (no worries as runflat tires come in 17 & 19 in. sizes as well). and yes , the run flat will allow you to still drive a short distance with no air pressure in the tire if you are not in the area of a tire shop . the sidewalls are reinforced(xtra stiff) to support the weight of the car even without air - the tradeoff for this is a rougher ride during day to day driving , hence the replies you are getting about the ride of the car w/runflats .
Thanks again.
Thanks again.
Also, there's no apron or room for error on most public roads... It gets rough in a hurry on the edge of the pavement...
Moral of the story: Keep your sneakers on the pavement!
Druther deal with flat tires with the Boxster than extreme high oil temperatures...
Reports are on the track, oil temp climbs high enough in just a couple of laps that engine enters limp home mode.
Even if one doesn't track the car, one has to be concerned about engine longevity with what are probably higher than "normal" oil temperatures.
Lastly, word is the non-turbo BMW 3 car is the better car, cheaper too.
Sincerely,
Macster.
