Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 987 Forum
Old 07-12-2009, 08:46 PM   #16
msh26
msh26's Avatar
pics
msh26 is offline   Reply With Quote
Old 07-12-2009, 10:33 PM   #17
DLennox
User
DLennox's Avatar
http://forums.rennlist.com/rennforum...1&d=1247445207
DLennox is offline   Reply With Quote
Old 07-13-2009, 12:47 PM   #18
flatspin
User
flatspin's Avatar
A proper break-in is essential for a tight, strong, long lasting engine. The break-in period accomplishes two things inside the engine on parts that rub against each other (bearings, piston rings, etc).
One is conformity on the parts. Internal lubricated components, such as bearings, are separated by a film of oil. Since no two parts are exactly perfect, it takes time for any parts to "wear" to a point that they are smoothly operating. This is not as critical in a modern motor due to the improvement in manufacturing tolerances, but it is still a consideration.
The second major function of an engine break-in is surface preparation. The surface of the inside of your cylinders looks like a rugged landscape under a high power microscope. As the engine breaks-in, the piston rings "lop" off the tops of these high points and slowly wear them down. The surface never really gets completely smooth; nor would you want it to, since the low areas collect oil and help lubricate/cool the motor.
This part of break-in is something of an art. If you are too easy on the engine, the rings might not completely "seat" and you will get "blow by", and increased oil consumption. This is from the rings not knocking down enough of the high points on the interior surface of the cylinder (These descriptions are VERY overly simplistic, and I am using them to emphasize the points). Conversely, if you run the engine too hard, too early; the rings will knock out large (relatively) chunks of cylinder wall. This will also decrease engine power and efficiency.
I personally find manufacturer recommendations to be very conservative, and by 500 miles most motors should be broken-in. You just need to be very gentle until the engine is up to operating temps (which you should be doing anyway ), use smooth throttle applications, vary your engine speed (no droning along on the highway for hours), limit your maximum rpm’s, and do occasional ¾ throttle accelerations to help the rings seat. I always stick to manufacturers recommendations for the first 100 miles, then increase the rpm limits by 1000 rpm for every 100 miles until the motors broken in.
You’ll find lots of opinions on breaking in a motor. So you need to take my opinion (and anyone else’s) with a grain of salt. Since your car already has over 1000 miles on it, this entire discussion is mute. The only reason I went to the trouble of listing all this info is in case someone else does a search and comes across this post. Congrats on the new car btw.
flatspin is offline   Reply With Quote
Old 07-13-2009, 01:21 PM   #19
DLennox
User
DLennox's Avatar
Thanks for everyones input. I have worked at new vehicle dealerships for 20years and have had many many new vehicles for company cars. My routine for driving a new car is pretty standard. I don't use cruise control till after 2000 miles, wait for engine to get to normal temp, I wait for idle to settle down on engine start up before taking off. I check oil and fluids regularly and don't push things until things are broken in. About the only thing the manual says for this car that is a little hard to stick to is not exceeding 4200 rpm......it gets there pretty quickly in 1st and 2nd so I have to watch it...other than that, I am not at all concerned with my driving habits or the break-in of this car. It is my first car of this kind and I am going to take care of it.
Dave
Old 07-16-2009, 01:07 AM   #20
fast1
User
I bought my first sports car, a Porsche 911 in 1968. Since then I've owned a variety of performance cars which I've kept for a minimum of five years and some much longer. During this 40+ year time frame I have never exceeded a company's recommendations for maintenance including oil changes, regardless if it's 3 months/3K miles or 2 years/15K miles.Although I have put over 100K miles on a few of these cars, I have never had to undergo the expense of an engine rebuild.
To me the most important factors in promoting an engine's longevity is to religiously follow factory recommendations, and to not take it easy on engine until it has been warmed up. I have to applaud BMW for their use of amber and red lights around the tachs of the M3s I owned. Some may think that it's overkill, but I thought it was a nice reminder to not wander in the 5K+ rev area until the engine is warmed up.
Although I admit that I would like to buy a used car from someone who has been as conscientious as some of the posters on this thread, I'm not certain that there is any evidence that these super maintained engines will last any longer than those that are maintained in accordance with factory recommendations.
fast1 is offline   Reply With Quote
Old 07-18-2009, 01:04 AM   #21
Gibson
Gibson's Avatar
Congrats DLennox, nice color which definitely stands out amongst all the greys (me included!).
If you care about paint maintenance you might look into claybar & polish to keep that red looking hot (I like Zaino).
And Macster, that's just amazing, 222k mi on a single engine/clutch!
Gibson is offline   Reply With Quote
Old 07-18-2009, 11:03 AM   #22
DLennox
User
DLennox's Avatar
Thanks Gibson. A neighbor informed me about Zaino. Looks like a lot of work!! My plans so far are for this to be a nice weather car, so the California duster, a nice coat of carnuba wax and hopefully I can stay away from the claybar. I am thinking about doing the Zaino process, I just have to find the time!!
Dave
Old 07-19-2009, 12:37 PM   #23
msh26
msh26's Avatar
Dlennox, try Klasse All In One for ease of application and great results. I have used several waxes and polishes and I have been extremely pleased with the glossy shine and durability. When I want a really lasting job with Klasse I put a coat of carnuba (P21S) on as the last step. There are several threads on Klasse. You also might check the 997 forum as well. Thanks for the pics.
Old 07-24-2009, 11:39 PM   #24
racer
racer's Avatar
I know salt can be a deterrant to driving your PCar in the winter, but I enjoyed driving mine when it was cold out. Made it seem a little bit warmer Plus, if Porsches get tested in scandinavia, driven to the alps etc, why not use it in the winter too?
1987 944
Past
2000 Boxster
1978 Euro SC Coupe
1976 914 2.0
1970 914 w/ 2056
racer is offline   Reply With Quote
Old 08-12-2009, 11:41 PM   #25
DLennox
User
DLennox's Avatar
I forgot to mention that I bought my car from "likemystoppie". Chris says to say hi to the fine folks here that know him and "whats up peeps?". I just saw him for my first oil change at 2000 mi. Still love my car!
Old 08-13-2009, 12:17 PM   #26
pdxjim
pdxjim's Avatar
Send a message via AIM to pdxjim
say hi to stoppie!
pdxjim is offline   Reply With Quote
Old 08-16-2009, 08:18 AM   #27
Besty
User
Hi Dlennox, in your opinion is the PASM option worth it? I am in the process of speccing a 2.9 PDK in the UK and thought the ride was pretty smooth without it on the 3.4S demonstrator i tried. I did some forum reading but none of it seems conclusive......
Besty is offline   Reply With Quote
Old 08-16-2009, 11:56 PM   #28
DLennox
User
DLennox's Avatar
Betsy, in every day driving, I would say it is not worth it. The car I bought was on the lot, so I took what it had. If I were to spec it out, I might not have picked the option. This care won't see a track while I own it, that is where you may see the difference. It does lower the car a little, so you do get that, but I haven't noticed a performance difference.
Dave
Old 08-24-2009, 02:45 AM   #29
Chris C.
Chris C.'s Avatar
Nice car, best of luck with it.
Chris C. (AZ)
Member No. 010817-2861
2009 Carrera S Cabriolet Arctic Silver, 6-spd!, Nav, cooled seats, Dynamic lights, SC, PDC, etc.
2007 GT3 Guards Red (sold!)
2006 Boxster S
1998 Carrera S
1997 Carrera
Bunch of Bimmers ...
Chris C. is offline   Reply With Quote
Old 08-24-2009, 12:42 PM   #30
DLennox
User
DLennox's Avatar
Thanks Chris, hoping to trade up into the 911 in a few years. We'll see...
Tags
911, break, breakingin, period, porsche
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
