Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 987 Forum
Old 08-06-2009, 07:31 AM   #1
Christian S.
Lifetime Member
Christian S.'s Avatar
Unhappy Knocking from behind driver (RHD)...
I wonder if anyone has had a similar knocking/rattle experience to this and could advise? Picked up an early 05 Boxster a month ago and proceeded to drive 3281 miles around France with it. Great fun and very happy with the car.
However on returning to the UK the car has started to develop a variable knocking sound that seems to be coming from behind the driver's seat (RHD). At first I thought it might be something loose in the door, but it has become louder and seems more rearward. It's a variable knock, that can be generated by poor surfaces, but does not seem directly linked to the suspension. It's also fairly low frequency and becomes less distinct when speed rises (due to overall noise).
It seems to be there regardless of the hood being up or down - although inevitable with the hood down, there's more general noise.
I'm about to attempt entry into the innards of the engine to see if anything has worked loose, but superficially, everything seems secure.
Christian S. is offline   Reply With Quote
Old 08-06-2009, 10:21 AM   #2
cviles
cviles's Avatar
It could be one of the control arms on the rear suspension. The bushings get worn and need to be replaced periodically. I had a similar noise on my '05 and the dealer replaced the arm under warranty and fixed the noise, so I can't give you an estimate of cost if that's the problem you have.
Chris
'07 Carrera S (Raawwwwrrrr)
'05 Boxster S (There is no substitute)
'04 BMW M3 (Now all my keys go into the left side...)
'02 BMW M3 (If you ever wanted to cut balsa wood with a chainsaw...)
95 BMW M3 (Still miss the telepathic steering)
93 MR2 Turbo (RIP - The wall wasn't kind to Mr. Two)
cviles is offline   Reply With Quote
Old 08-07-2009, 06:38 AM   #3
Christian S.
Lifetime Member
Thanks cviles - I'll get it up on the jacks and have a look at that - maybe swap both sides out while we're there.
Christian S.
Old 08-21-2009, 05:15 AM   #4
berty987
User
Does the car have the optional PASM ? The shocks can be prone to wear giving this noise.
berty987 is offline   Reply With Quote
Old 08-24-2009, 04:05 PM   #5
Christian S.
Lifetime Member
Quote:
No, it's standard I'm afraid. Interesting though, as the sound has got steadily worse and is a constant feature now - sounding more "spring like" ie. a tension sound - I wonder whether the top mounts are prone to wear?
Christian S.
Old 10-06-2009, 06:00 PM   #6
litteng
User
Default possible known problem
i assume from you posting that you have a 987 model, but you state no information regarding mileage.
there is a tech bulletin issued regard a piston knocking which occcurs in the oil pump.
my car was doing as it was warming up and rev's were between 2 - 3000 rpm.
dealer repair under warranty in my case, problem banished
check to identify when it occurs, then talk to the dealer...
litteng is offline   Reply With Quote
Old 10-06-2009, 06:08 PM   #7
Christian S.
Lifetime Member
Quote:
As stated in my original post, it's an early 05 model - 987. Mileage is 40,000 , however it has spent most of it's life in Edinburgh, in the New Town where the streets are still cobbled. Definitely a suspension related issue - happening regardless of rev range.
I'm about to take it to an independent shop, hopefully they will be able to diagnose and repair it using experience, rather than my guesswork! Thank you for the suggestion nonetheless.
Christian S.
Old 10-06-2009, 06:41 PM   #8
ricster
My guess its the intermediate shaft about to go south
ricster is offline   Reply With Quote
Old 10-11-2009, 07:49 PM   #9
tinman
Send a message via MSN to tinman
what would the IM shaft repair cost in USD$, and can you give some background about, how, when, why.....
thank you
______________________
Howard L.
tinman is offline   Reply With Quote
Tags
2001, 911, boxster, boxter, carrera, front, intermediate, knock, knocking, louder, lower, m3, mr2, noise, porsche, rear, shaft, suspension, time, toyota, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
