Thicker tires?
Thicker tires?
Hi all,
I have a stock 2007 Cayman S (without chorno and suspension control and other goodies).
I am currently using stock 35/40R18 front, and 265/40R18 rear tires (N4).
I found my ride really bumpy and quite harsh on the bumps, also make bumpy sounds, bounce around and stuff, I live in Hong Kong, roads here are pretty bumpy.
I am wondering if getting thicker tires can help this problem like:
35/50R18 front, and 265/50R18 rear?
And how will getting thicker tires affect my car? like handling and acceleration.
Thank you in advance!!
I'm sure you meant 235 for the fronts. Anyway, you should lower tire pressure first since higher tire pressure means stiffer side wall and you will feel more bumps.
Try 40 or 35 psi all around and see if that is sufficient.
NO, higher pressure makes the tire more stiff and the ride more harsh, two things you don't want when you are trying to reduce the harshness.
Try 35 PSI, if not then you will just have to get used to the ride quality, these cars are not made to be comfortable like a Buick sedan, so they will feel harsh on poor road surfaces, not a whole lot you can do.
you cannot change tires to any sidewall height you want, you have to match it with section width, otherwise you get ABS and speedo differences which will eventually make your car unsafe. Recommended difference in wheel diameter is less than 3%. Going to 265/50 from 265/40 is 7.9% difference so no recommended. You will have to decrease your wheel diameter to either 17 or 16 inches which will improve the ride comfort and decrease the ride handling.
Stay within the recommended tire pressure or you will have a blow out.
The harshness you feel is directly suspension related. If you want to deal with harshness then you can
Change to smaller diameter wheels/so higher profile tires
Change shocks and suspension.
Get a lincoln, toyota or Buick
16" rims will not fit on a Cayman S and 5mm spacers are needed with longer wheel bolts (GT3 size)(on the front) if you go to 17" rims or the wheel won't spin. Seems that they are pretty snug against the front brake caliper. However, being a track guy, I have found that good tires on 17" rims seem to work better than the larger rims and tires are little less expensive.
