Looking to add a Cayman S as a DE / eventual track car
Old 12-30-2015, 07:20 PM
Surfer161
Surfer161's Avatar
Originally Posted by Derek978
Ended up with this one:
https://rennlist.com/forums/vehicle-...rack-prep.html
I will pick her up Tuesday.
congrats. please report once you get miles in it.
Surfer161
Old 12-31-2015, 09:50 AM
Derek978
Derek978's Avatar
I have the brake ducts on order form Suncoast. I will keep an eye on the PS temp during the first few days and add the extra cooling if it seems questionable.
Oil change and brake fluid flush are next. Followed by finding a set of "street wheels".
Thanks for all of the advice guys.
Derek
Old 12-31-2015, 11:05 AM
DaveCarrera4
DaveCarrera4's Avatar
I have the brake ducts on order form Suncoast. I will keep an eye on the PS temp during the first few days and add the extra cooling if it seems questionable. Oil change and brake fluid flush are next. Followed by finding a set of "street wheels". Thanks for all of the advice guys. Derek
what did you pay for the front ducts, or more appropriately diverters? Sadly, the rear brakes suffer overheating more.
Old 12-31-2015, 01:15 PM
Frank 993 C4S
Frank 993 C4S's Avatar
They cost about $30
Your rears should not overheat. High brake pad wear due to PSM - yes, but they should not overheat.
Old 12-31-2015, 04:34 PM
HoBoJoe
HoBoJoe's Avatar
The GT3 brake ducts can be purchased directly from your local dealer, just ask for them for a 997 GT3. My parts guy is always able to find exactly what I want and these were surprisingly cheap.
Or hit ECS tuning up:
https://ecstuning.com/ES2526435/
Old 12-31-2015, 04:40 PM
DaveCarrera4
$8? Wow! Great price. Don't forget to drill a few holes and add zip ties!
Several attempts made by others to divert cool air to rears, nothing simple out there yet. Current retrofits have all required extensive mods.
Old 12-31-2015, 05:29 PM
Dr.Bill
Dr.Bill's Avatar
996 turbo ducts on the rear brakes work with the 987.2 Cayman. Not sure of the 987.1. Does need a bit of trimming and some zip ties. The rear calipers can and will get hot due to the PSM. They turn a nice red-brown color with track use.
Old 01-01-2016, 11:08 PM
DaveCarrera4
very true. PSM off is almost a requirement.
Old 01-02-2016, 07:40 PM
Surfer161
Surfer161's Avatar
you only have to turn PSM off if you drive fast enough.
GO FAST GO NAKED.
good luck
Surfer161
Old 01-03-2016, 11:16 PM
DaveCarrera4
Originally Posted by Surfer161
you only have to turn PSM off if you drive fast enough. GO FAST GO NAKED. good luck Surfer161
exactly, as the thread title prescribes, Track/DE.
Old 01-04-2016, 10:04 PM
Derek978
Derek978's Avatar
Going to be some learning going on before running without PSM for me.
Currently shopping for a set of wheels / tires for street use to save the track set. Currently shod with Nitto track tires...
First oil change tomorrow (have the week off, starting new job next week). Brake fluid change on deck once track season gets closer.
Old 01-04-2016, 11:36 PM
DaveCarrera4
Going to be some learning going on before running without PSM for me. Currently shopping for a set of wheels / tires for street use to save the track set. Currently shod with Nitto track tires... First oil change tomorrow (have the week off, starting new job next week). Brake fluid change on deck once track season gets closer.
what tracks do you run?
Old 01-05-2016, 01:13 AM
Derek978
Derek978's Avatar
Mid Ohio is close, the local PCA also does events at Nelson Ledges and Pitt Race, recently.
Old 01-05-2016, 11:26 PM
DaveCarrera4
heard Pitt is now pretty good! Ran mid O last fall, very fun!
Old 02-13-2016, 09:09 AM
cavlino
cavlino's Avatar
Originally Posted by bernb6
I've had both. I decided to not track my 987.1 and bought a .2 for DE. Given the price differences, .1 or .2 is a personal risk decision. Here are three links that will help you decide:
Good technical summary of .1 oil starvation problem
http://www.planet-9.com/987-cayman-a...sure-data.html
Good discussion of pros/cons of .1, .2
http://www.planet-9.com/987-cayman-a...r-gen1-cs.html
Cayman interseries using the 987.2
http://www.planet-9.com/the-cayman-i...e-learned.html
Good luck with your decision,
Bern
Very useful info, thanks!
Quick Reply: Looking to add a Cayman S as a DE / eventual track car
