Clutch Smell
Clutch Smell
I bought a used 2014 4000 mile Boxster S with a 6 speed and chronos. Interestingly, when I put the car into Sports plus and drive the car with a little more spirit, afterwards I smell what appears to be clutch odor resonating from engine area. Oh and Yes, I do know how to drive a manual. Is this normal? I would assume the car has been broken in. Any suggestions? I am thinking of taking it back to the dealer to see if there is a problem. Thanks. Kevin
My dealer told me to let the clutch out further than I would expect before I apply the throttle. I experienced the same smell on my first drive and the valet even commented on the odor as a burning clutch smell.
I find that my Porsches often smell after a spirited drive. I suspect that it is cosmoline or other protective stuff that surprisingly lingers for many many years. My 981 is also a 2014 S with the proper transmission, around 15K miles, and it will stink a bit. My previous 997 (911) also smelled after a drive. It's just the nature of the beast.
If you know how to drive and you know that you aren't slipping the clutch, then don't worry about it.
