991.1 GT3 COG: Our Meeting with PCNA/PAG plus Porsche's Official Announcement
#496
Stick with it, every maker screws up every now and then. Porsche got caught on this one and did right, 10 year engine warranty. Would I hold on to the car without a fix or a 991.2 GT3 engine in it past 2025.....
Pretty simple to pull the valve covers and see if there's wear, but many dealers don't do it... Push for it
#497
Hey All,
I have a 2014 about 25,000 miles and just got green light for engine replacement. Anything I should make sure to ask dealer for during the process? Some people get cars CPOd after replacement? Thanks in advance.
#499
This extended warranty only covers the engine, and then only the internals. So CPO takes care of the PDK and all sorts of other things. BTW, how does she run with the new engine?
#500
Just changed oil after 1K miles and ready to get her back on track!
Thanks for asking...
robmypro (05-28-2020)
#501
Not really. I would definitely take pictures, if possible, to document the process for your own safekeeping and if you ever sell the car.
I would also confirm/document the serial number of the new engine, should start with G##### just to confirm your replacement motor is the "fixed" version.
I attached pic of mine
#504
Engine replaced
Hey,
Just wanted to chime in. I’ve got a 2014 with 24k on an E motor that was fixed by Porsche before shipped to US.
Car has been tracked a few times by previous owner, no issues were reported to my knowledge. Car serviced at same dealership since new.
After I purchased the car, started getting cold start faults pretty consistently.
Initially, dealer said faults were related to not being driven enough. Cleared the fault and sent me back out. Fault returned.
Dealer then said fault related to low battery. Replaced. Fault returned.
Dealer then said fault related to spark plugs. Plugs were new, but they replaced anyway. Fault returned.
Dealer replaced coils. Fault still there. Dealer replaced injectors. Fault still there.
Dealer then got a secondary air fault. Checked all lines and ended up cleaning carbon deposits. Said with 100% issue was fixed. Fault returned next morning...
Dealer dropped the motor at my request and found “unusual wear on cylinder 6”. Engine is being replaced.
Engine coming from Ontario California. It’s the G.2 motor. And it’s a remanufactured motor. Said these engines have been pretty trouble free. Fingers crossed.
Dealer expect to have car back to me end of next week.
I never experienced a fault while driving, hitting redline, or while car was warm. Mine always threw a fault during cold start.
Hope this helps someone.
#506
Porsche said all G6 motors being used for replacements are remanufactured motors. I would not be surprised if most of the motors used for replacements (F - G6) were likely remanufactured motors and not "brand new". Looking at the crated motor, I can see why people would assume these are "brand new".
#507
Well...good question! I was told this is 'what you get and don't pitch a fit'...everything is new except core/block, so essentially a new motor.
Dealership also said cost for re-manufactured vs. new is significant....~$50K vs. ~$90K ....not sure why?!?
I'm sure if you wanted new, you could get one if you picked up the cost difference.
#508
I received the same explanation. My dealer called it "remanufactured" - which may just be their terminology.
#509
#510
I find it a lame answer. If the donor core was damaged by metal bits and pieces floating around then the “remanufactured”unit may turn out to be a piece of sk..t. I would have to guess that as warrantor of the unit Porsche reserved the right to replace a part with a refurnished one. Very common in the insurance of used cars. Could be a ticket to a third engine.
robmypro (06-15-2020)
