Are you sure that is for a GT3? It shows online as non-GT3 and it is about 10k (which actually seems within the range for Porsche parts).
upper left corner of the photo, it clearly says "Model: 991GT3". so either this source or your source is wrong... or (more likely) the non-GT3 and GT3 share that same part?
I do not know, I just looked it up on Sonnen Porsche. Could be the same part.
It actually says "Model: 991G13" in 2 different spots
If you go to XPort auto parts Inc that is the front end for the Turbo or Turbo S, but may be all be the same across all models
wow. this should be interesting. Look forward to seeing the completed job. Best of luck to your friend.
yes, i have no clue how they'll deal with the welding to the rest of the body. i'm no engineer, so maybe welding is just welding, as long a you have a decent TIG (?) welder.
he plans to convert it to a pure track car, so they may end up seam welding the chassis anyway.
