991 GT3, GT3RS, GT2RS and 911R 2012-2019
Would you worry about buying a brand new car that has sat for 3 years?
Old 10-31-2018, 09:54 PM
96redLT4
96redLT4's Avatar
Default Would you worry about buying a brand new car that has sat for 3 years?
I am looking at this gorgeous 911R from John at PNH. I have a 2016 GTS currently with 10,500 miles on it. I don't have a ton of miles on mine, but I can't imagine it having sat for the last 3yrs after being newly constructed. Would you worry about fluids, gas in the tank, tire life or rodents chewing on the wires where it sat. Is it reasonable to demand to know where the car has been for the last few yrs? I guess the bottom line is how old is safe to buy new?
https://rennlist.com/forums/vehicle-...016-911-r.html
Jim
Old 10-31-2018, 10:01 PM
neanicu
neanicu's Avatar
I wouldn't. But for that money you can definitely ask for CPO,which will make them do their 100 point(or whatever) inspection.
bbs993tt
bbs993tt's Avatar
Jim
ABSOLUTELY!
0to60
0to60's Avatar
Ask Paul Walker
Old 10-31-2018, 10:08 PM
Akunob
Akunob's Avatar
Of course I’d buy it. Just have the car checked out, by a qualified technician, like any other purchase.
Old 10-31-2018, 10:19 PM
RDM2418
RDM2418's Avatar
That car was at the St. Louis store before Houston (likely in showroom). In my experience with Indigo (PNH and Porsche St. Louis) (1) they move the cars around periodically, so it would get started, etc.; (2) if there are any issues with the car, they'll address. I think the modern 911s can sit for longer without issues. If it was an older one, I'd be more concerned (but see point (2)). The St. Louis guys probably know the story on the car before it came to Houston (or Tino will).
I'd call Mike Yale (Service Director) and ask him what he thinks. He's a straight shooter and will tell you if you should have any concerns.
I saw that car today, it looks awesome.
Old 10-31-2018, 10:41 PM
SmokinGTS
SmokinGTS's Avatar
Tires and fluids that's all you need.
Old 10-31-2018, 10:47 PM
signes
signes's Avatar
Don't worry, modern car. Check the battery and tires for flat spots, oil change and go. And it's only two years old at this point.
Old 10-31-2018, 11:29 PM
Ascend
Ascend's Avatar
It's not some piece of junk that's been sitting somewhere in dealer parking lot for 2 yrs. It's 911R.... I'm pretty sure dealer took good care of it.
Old 10-31-2018, 11:34 PM
richk
richk's Avatar
+1
Old 10-31-2018, 11:40 PM
GT3RS-Fan1
GT3RS-Fan1's Avatar
Fully agree. Change all fluids and if tires are four years or older simply replace.
I like to buy garage queens for the simple reason I know it was not abused.
Drive safe,
GT3RS-Fan1
Old 11-01-2018, 01:03 AM
17bhub
17bhub's Avatar
Location: Where I get the fresh scent of spent Jet Fuel & see Cold Smoke!
this!^^
Old 11-01-2018, 01:06 AM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
I would smell the gas, drain/pump if at all suspect (not sure how to do that on a 991), if not fill with new, I would do an oil change, maybe a brake fluid change, but no, would not bother me. Tires should be more than fine if sitting indoors, even outside, get them hot and the flat spots will go away. 3 years is nothing. I would not pay a premium for a no miles new car as I like drivers so unless you plan to keep it no miles, I would save a few pennies and find one that has been driven. However, assuming price is acceptable, no issues from my perspective with sitting for a few years.
Non-Porsche story: To that end, and I know this is about as far as far away as possible from a no miles 911R, but my gf said she wanted a Jeep so I went on craigslist and found a 27 year old Jeep YJ with nearly 200k miles that had been sitting for 5 plus years. Forked over the $1500 asking price because it was an auto Sahara with hardtop and AC, no ABS, but as a 91 plus the 4.0 high output with EFI (desirable spec, the 911R of YJs if you will ) and had no frame rust (try finding a Jeep around here with a good frame — I have had enough fun doing chassis replacements on Land Rovers to save that for defenders which are worth 20x what the Jeep is). Other than corrosion repair related items such as brake lines and some body panel welding (corrosion is not applicable to your situation I should think), fresh fluids and a battery and it was fine and has been giving good service. I did it because I wanted a reasonably “quick” project that would make someone I care about happy. I know this story confirms I am nuts (I could have just bought a new JL or preowned JK or something) but my point is that, while it is sub-optimal for cars to sit and I prefer them to be driven regularly, it is not a big deal in most instances if they do sit, especially as the car will be in warranty and you bring it current on service.
Old 11-01-2018, 10:47 AM
robmypro
robmypro's Avatar
Received 1,772 Likes on 1,020 Posts
If the car really sat for 3 years just make sure the car is thoroughly inspected, including for any damage caused by mice. I doubt any damage occured but i would check for it.
Old 11-01-2018, 10:54 AM
Maverick787
Maverick787's Avatar
Received 2,082 Likes on 1,006 Posts
Definitely change tires because of possible dry rot, and a must if the car will be driven at any high speeds.
Quick Reply: Would you worry about buying a brand new car that has sat for 3 years?
