Trailer Tie Down the 991.2 RS
How are you tying down your RS when transporting in a trailer? My 996 GT3 has eyes bolted to the suspension front and rear. When the 2019 RS is transported to and from the dealer they go through the wheels. Does someone make suspension eyes similar to what can be used on the 996 and 997? What are your experiences?? (and if there is a thread I can't find, point me in the right direction)
I use the Rennline tie downs on a .1 RS. Fronts are easy to use, rears are a rather long reach to attach, may be even more difficult with the .2's new rear diffuser getting in the way of clearance.
After a long drive over bad roads, I had an issue with trailering the car with tie downs at the wheel: https://rennlist.com/forums/991-gt3-...railers-2.html
I tried the Rennline tie downs, but didn't like the idea of permanently covering the front jack points or unbolting/bolting bolts on the subframe. I ended up with these instead: https://parts.ectts.com/towing-t-hoo...k-ba-products/ . Easily and securely hooks into the holes at the jack points,, easily removed when done.
this is the best. works on any other car you have too. (if you remove the jack pads)
Would it be bad to strap the front the of rs just by the tow hook and transport it like that?
