JCR Race Pipe Vs Soul Modular System: the good, bad and ugly
#61
I'll also say that the race pipe volume is loud when just cruising at low rpm, but it's way, way quieter under those conditions than it is at WOT. WOT vs low load, low rpm is night and day. Be warned if you have family, the cold start, in the garage, is going to wake up your house. There is no sneaking out period.
#62
I plan to make several videos of mine when it arrives with all different driving RPM Sounds. Having had 5+ different systems on my car, i wanted more of the RSR noise higher end but also something that sounds more prominent on the street lower down.
#63
did you get race or silenced race?
#64
After loosening all four clamps yesterday morning and trying to get the exhaust back into place I failed. The tips are in the same spot as before I got under the car so clearly I'm doing something wrong. I really don't want to take it to my shop again to have them monkey with it but may go that route at some later date. I'm not driving much these days so it may be like this for a while.
#65
#67
What helped me was loosening all 4 clamps, and placing a floor jack underneath to support the exhaust at the tips a little higher than the desired height. This made the exhaust where it meets at the cats to be angled upwards a little. I then tightened the clamps at the cats, and then the two clamps at the silencers. After removing the floor jack the tips dropped some as expected but the height of the exhaust is mostly where I want it.
#68
^^This was my point, it needs to be adjusted at the cats. I do what you describe, only without the floor jack, just holding up exhaust with one hand, tighten cat clamp with the other.
#69
#70
https://rennlist.com/forums/991-gt3-...t-bracket.html
Soul commented on how to support GMG center section with their side delete. They recommended using Mikalor Band Clamps to fit around the CMB and the Lower factory tab. This may be the solution here. But maybe would need to hook it up to the upper tab give the curved pipes on the JCR.
Here is a photo:
Here is a photo:
991.2 Gt3 Rs (07-29-2020)
#71
If you loosen the cat clamps, and loosen any clamps holding the rear section to the engine block (if you are using any), there is no way the exhaust, and also tips, cannot be moved up and down.
#72
I could move the entire exhaust up where it was supposed to be but it still fell after the clamps were tightened so I don't know what's up.
#73
Basic Sponsor
I think you’ve found the issue. Thankfully a simple fix
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
#74
Unfortunately it sounds like the clamps aren’t clamping. If the exhaust is not secured by the clamps once tightened and shifts even with the clamps bottomed out then they have stretched and lost their ability to properly secure the flange on the JCR part to the headers
JC
JC
#75
Maybe JCR can chime in here:
you said it is not wise to mount the center bypass part of your race pipe to the oem mounts because of increased vibration......but Soul, Sharkwerks, and quick fixes like above for GRP/GMG are done. What makes your system different to not mount the center? Just curious....
